Question about Texas Instruments TI-84 Plus Calculator
I cant use the buttons on the calculator. ex. if i push 1 it does not come up on the screen.?
  • kakima May 11, 2010
    Are the buttons not working, or is the screen simply blank? If the latter, turn the calculator on (or at least press and release the ON key), press and release the 2ND key, then press and hold the up-arrow key for a few seconds to see whether the screen becomes legible. Does this do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 02, 2010
My calculator screen is dark and the cursor isn't blinking and when I turn it off its still on the screen and I cant push any buttons
To reduce the contrast
Press the [2nd] key and release it.
Press the [DownArrow] key and hold pressure.
The screen will become lighter. Release the down arrow when the screen is to your liking.
Sep 01, 2015 | Texas Instruments TI-84 Plus Silver...
How to calculate standard deviation
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
Sep 23, 2011 | Texas Instruments TI-84 Plus Silver...
When i turn on my calculator, my screen goes blank. i can still see the numbers i type when i look at the screen at the right angle, but it is a problem. i think it was a button i pushed, however, i cant...
Try increasing the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the up-arrow key for a couple of seconds and see whether the screen darkens. If you go too far, repeat the process with the 2ND and down-arrow keys.
Jan 10, 2011 | Texas Instruments TI-84 Plus Silver...
Where is the exponent bottom?
the exponent button looks like ^ push that and type in the number. For some equations and also negative numbers you may have to put parentheses.
Ex, 9 * 7^(-5)
Jan 26, 2010 | Texas Instruments TI-36 X Solar Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [2nd][+] (") to access the double quotation mark
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
How do you take the 3( square root) of 64 or the 4 root of any other number? im trying to take the 2nd button but still having trouble ? can u please help?
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
Hope that helps.
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
TI 84 Won't turn back on
Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Jan 11, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
63 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
