Question about Kodak Office Equipment & Supplies
I have a Kodak Ektagraphic AF-2 projector. I went to use to show my class some slides and it jammed. Not the carousel, the projector mechanism itself seemed to jam. I thought it I took the carousel off and worked the changer, it would clear, but it is still stuck. And there is no slide in the mechanism. I took it to a repair place that repairs cameras and projectors but they wanted $160 minimum. Way too much. I'd rather fix this sturdy old projector than heave into a landfill. Surely you can suggest something i can do to repair it myself. Thanks, Jim Bull
  • 1,606 Answers
Basically all you need to do is a real good cleaning.If the mechanism was able to clear then the problem is going to be dried oils or varnish. The slides will stick on these buildups and you get your problem.
You can start off trying some simple things. The oils used were a peteroleum based light oil something akin to 10 weight sewing machine oil.You need to be very careful about oiling as you want is a film of oil on the parts. Anything more and you risk the excess oil getting on your slides.
So what you want to do is get some ispropyl rubbing alcohol and cotton swaps. This shouldn't attack the plastics but you can check that by putting some on in a hidden spot ie bottom. First start wetting and cleaning the slides. As the iso gets into the buildups you will start to see more gunk/dirt on the swabs. It may take a few goes before you see this depending on how hard the buildup is. And it will take a bit to clean it. When you are done the swab will be clean and the machanism will move smoothly up and down again. At this point you want to put a drop of sewing machine oil on a swab and gently wipe the tracks and any moving parts that contact. As well as any hinge points.
Basically the varnish is the main problem and this will show up on the reacks or in the pivots. You can also get this if the springs are worn out.
Usually it is just the dirt/gunge/varnish and nothing else. The reason they said $160 is that this isn't hard to fix but takes a lot of time.
Posted on Apr 28, 2010
Kodak Ektagraphic AF-1 will not advance or reverse
If the select button functions correctly, Chances are the direction lever in the mechanism is bound up or the Direction Lever Spring is broken. If the Spring is broken or the Direction Lever is bound up, the Index Lever will go out straight when the Advance / Reverse buttons are pushed - instead of moving out straight , then moving forward or reverse at a 45 degree angle.
The Slide Change mechanism needs to be re-built. The bad news is this projector was manufactured from 1976 to 1984. Kodak scrapped the repair parts in the early 1990's. Your best bet is to find a repair shop that has a projector that they can salvage parts for your projector from.... Good Luck !!
Dec 26, 2013 | Kodak Office Equipment & Supplies
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Why doesn't the slides advance?
I can only guess, but it is most likely caused by a worn or mis-adjusted cycle contact. I have attached an illustration to show you the proper orientation of the cycle contact. Good Luck !! Jim7390f9e7-725d-4085-9769-5537112e57b1.jpg
Aug 10, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
Kodak Ektagraphic model B-2 slide projector.- It does not start. I checked the power cable and motor OK but I don't know how to reach and check the thermal fuses. I also don't know how to reach the...
If the motor is "OK" (turning), then it's not a fuse, it's the belt that the motor drives to power the slide change mechanism. There are 2 belts: 1 that drives the fan & one that drives the slide change mechanism.
Nov 02, 2010 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
AF-3 carousel, lamp on but light guard prevents picture
Based on your description, I suspect the coil spring that tensions the "dark shutter" has either broken or has popped off it's mount. To be absolutely sure, take your projector to a factory-trained repair dealer.
Feb 13, 2010 | Kodak Ektagraphic III E Plus Slide...
I need a instruction manual for the Kodak Ektagraphic AF-2 slide projector.....Where can I find one.....It is a 80's model with the round carousel at the top....Thanks...Susan
I believe they still have a .pdf version in the Kodak website (www.kodak.com - then search on "slide projectors).
If you have a specific question, re-post that question & I'll give it a go...
Apr 10, 2009 | Kodak Office Equipment & Supplies
Autofocus
the only way to do that is disconnect the red, black and grey wires from the autofocus switch assembly, but you have to take the projector apart to get to it. if you do, it's on the bottom right side (facing the front of the projector) of the lens.
Oct 07, 2008 | Kodak Carousel 4600 Slide Projector
50 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
