Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Brush bar is not turning when I turn on my dison vacum
  • 438 Answers
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Posted on Apr 28, 2010
  • Koinonia Aug 29, 2010
    where do I find this reset switch behind the brushes? I have taken everything apart and can't find it. I also have the DC15.
    Thanks
My dyson seems to have the same issue...I have pressed the reset button, my brush button is depressed and won't do anything....
Posted on Nov 13, 2012
  • 3 Answers
Hi all Dyson DC 15 brush Barr not working. Have followed all your sugestions. Thankyou. Have pulled machine apart. Brush bar motor burntout and this has damaged the circut board.
Posted on Feb 26, 2011
The bristles will not turn when vacume is on and I try to vacume
Alot of those vaccums have a little drive belt on them. You might look for that. Also some string might be caught on the side of the brushes.
Sep 13, 2014 | Vacuums
My dison dc25 beader switch does not work?
Hi there, it's Jack at Dyson.
If your DC25's brush bar won't rotate, please follow the steps shown in the video below to check the cleaner head for obstructions:
Please note, the brush bar will never rotate when the vacuum is standing upright. Make sure you recline your machine into the normal vacuuming position before testing it. You may also want to press the silver brush control switch (next to the red on/off switch) twice to ensure it's correctly engaged.
If you continue to have difficulty, please get in touch with us directly so our experts can provide further assistance. If a repair or a replacement part is needed, we can also confirm if this is covered under our 5-year guarantee. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 13, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Apr 18, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover S3755 WindTunnel Bagless Canister Vacuum brush not spinning
The belt might be streched or broken,also you could have dirt in the bearings on each end of the brush bar. either one of those will cause it not to turn. You will have to remove the brush bar to check that is does not have debris in it. you cant tell from just looking at it still in the vacume.
Jan 06, 2013 | Vacuums
Rotating brushes don't spin.
Turn it over and pull out the brush holding assembly and insure that the master brush's stem is not broken off in the socket. The socket is geared to the vacum operated turbine that powers the brushes. There is the air input located next to the brushes and the filter might be clogged. If no air is being sucked into this red filter then it will have no vacum to turn the brushes. Insure that the flap is not closed behind the input filter. The flap is controlled by the brushes on selector switch.
Jan 29, 2011 | Hoover F5888-900 SteamVac Upright Wet/Dry...
Brush wont turn loose belt, new belt no help
may need to clean or replace beater bar. take brush out of vacum hold on the end and try to turn brush
Nov 26, 2009 | Vacuums
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
1,895 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
