Question about Ecoquest Fresh Air Air Purifier
Fresh Air will not work after cleaning
We have had our Fresh Air for over two years and have cleaned it accordingly every month without problem. This time, after cleaning, the LCD screen lit up with the usual content present. However, when I pressed the reset button, all words disappeared (but the screen remained illuminated) but the unit would not come on. Only the blank LCD screen is illuminated. I checked the fuse and it is ok. I re-checked the wiring inside and all is ok. I have tried unplugging it and replugging it into the outlet. Nothing works except the bland LCD screen. What is wrong? Thanks.
Larry Little
    Problem Solver:
  • 11 Answers
How well did you clean it, there are 2 connections to the lcd screen up front maybe one of those became unpugged. You have to be careful cleaning around the circuit boards because body static can ruin a circuit board. Its possible that happened . I had a problem with a lcd screen going bad and the unit would not come on and just stay lit like your describing. I replaced the screen and it was fine.
Posted on Apr 29, 2010
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
Fresh air 2, blue light goes out, fan still works, reads
If the light goes out, it is time to replace the bulb AND the bulb starter. They need to be replaced every two years. Beyond that, they are an expensive night light. If you need to order one, call (336) 499-2505. Also ask for supplemental cleaning instructions since the original instructions are incomplete.
Jun 10, 2012 | Ecoquest Fresh Air Air Purifier
My EcoQuest Fresh Air unit stopped working. The fuse seems to be good. It will not turn on. Any suggestions?
A common problem with the Fresh Air when they are not cleaned regularly is heat build up, which may cause circuit board failure. There are two processors on the circuit board which burn out. The circuit board can be repaired rather than replaced at a very reasonable cost and one repair facility will guarantee their work for 1 year. Call toll free (336) 499-2505 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
Jun 08, 2012 | Ecoquest Fresh Air Air Purifier
When I attempt to turn the unit on, the display flashes but wont stay on
The main circuit board is bad. The circuit board can be repaired with a one year warranty. Call (336) 499-2505 for more information.
May 23, 2012 | Ecoquest Fresh Air Air Purifier
My fresh-air by Ecoquest is about 4-5 years old and I've cleaned it before. Planned to clean it today and cannot find the cleaning manual. How can I get another one?
Call 800-989-2299 and ask the customer service rep to email you the manual or give you the site where you can download it. Use 16618 as your dealer referral number.
Feb 02, 2011 | Ecoquest Fresh Air Air Purifier
How often should you clean the plate?
when you notice the 'fresh air' smell in the room isn't s good as it used to be. Anywhere from monthly to 3-4 months
Dec 09, 2010 | Alpine Air XL-15 Air Purifier
I have 2 Ecoquest Fresh Air purifiers located in oposite ends of my basement. One in my work shop area (approx 28x32) and the other in my finished basement area (approx 28x50). The reason I chose this...
Hi Ed,
You should also clean the contacts points that touch the plates with the amonia and water solution. Use a brush and to remove any deposits on those contacts. Also the purification plates will not work if they are still damp when they are put into the machine. They must be completely dry in order to work. Use a hair dryer to dry off any water on the metal grid or allow them to dry for 24 hours. Hopefully that should get your plates going again.
In regards to when you should replace the plates. As long has the plate material is not cracked and you can clean the metal grids to a shine they should be good. But they should be able to last several years with good maintenance.
The RCI cells should be replaced every 3 years or when the machine displays "Replace RCI" message.
Hope this helps you.
Dec 04, 2010 | Ecoquest Fresh Air Air Purifier
I have a Fresh Air Unit from Ecoquest. The
When that message appears the plate does not make good contact with the two contact points. You can use rubbing alcohol and a q-tip to clean the points. After 1-2 years it is also advisable to change the purifier plate. Plates are about $15 and can be purchased at EcoQuest.com
If the plate is dirty (and this can unnoticeable grime-grease) clean the plate with 1 part clear ammonia and 1 part water. An old tooth brush works great.
Dutch
Apr 16, 2009 | Ecoquest Fresh Air Air Purifier
Cleaning the fresh air purifier
You have cleaned the purifier. Now on the front there is a reset button next to the power button push that to reset cleaning cycle.
Oct 10, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
243 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
