Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
Farmall 560 hydrolics wont work on the bucket
I got a farmall 560. i have a bucket and the hydraulic lever that usually raises the bucket is now working the rear hydraulics instead. is the a cut off switch or something. thanks
    Problem Solver:
  • 20 Answers
Make sur you dont have lines switched. check fluid levels and lastly check th pump for week lobes
Posted on Jan 18, 2013
    Problem Solver:
  • 14 Answers
I am not sure but check the levers and the inside of the lever control movements.
Posted on Aug 17, 2010
Farmall 856 hitch does not raise in zero weather
ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
Jan 21, 2016 | Farmall IH Tractor 706, 756, 806, 856,...
Wiring diagram 560 farmall 560 tractor
try searching for a tractor forum like OLDIRON
Jan 05, 2016 | Farmall IH Tractor 460, 560, 660, 2606...
Case IH DX29 Hydraulic prob. bucket wont lift
Check control cable from lever to valve to see if it has broken or seized
May 08, 2012 | Farmall Toys
Where are hydraulic fluid drain plugs located on farmall 560
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
The transmission on my 560 Farmall is stuck in gear how do i get back in neutral?
loosen the bolts around the gear shift and put the shifter back into the slot that is not lined up in the center usually it just slipe out and you cant change gears even if it feels like you are.
Nov 26, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Transmission stuck in gear
dont know if i answered this one or not you have usually just slipped the gear shifter out of the notches in the transmission ( I heard there is a fixit kit for aprox $400 but never could justify) 1. take off the shift lever (3 bolts). 2. look in the hole and find out which one of the parts are not in line (all notches should be in the center of the hole to be in neutral) put gear selector in wth the tip in the slot or notch that is out of alignment. push down and try to move back to neutral.should move relatively easy.when all are lined up tighten back up (check your transmission fluid hydraulic fluid at this time as it is easiest to add it through the shifter hole. Full plug is located below the clutch pedal and fluid should come out when it is full.
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
476 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
