Question about Bosch Classixx WFL 2066 Front Load Washer
We are getting small holes in our clothes from the Bosch washing machine, they are air dryed. We have looked inside the machine and there are no sharp edges, what could it be? regards Fiona Hainsworth
gittos73
  • 244 Answers
SOURCE: Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Posted on Aug 22, 2007
SOURCE: rips and tears in clothes
The washer could be developing a transmission problem. As the washer agitates, the plastic tub is suppose to remain still. If the transmission is starting to slip, it will also try to spin during the agitate cycle, thus making the clothes become tangled under the agitator.
Posted on Sep 27, 2007
  • 51 Answers
SOURCE: holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Posted on Mar 13, 2009
barkencoa
  • 3463 Answers
SOURCE: Oily substance collecting in the door's rubber seal.
It is not oil, but a build up of grease and living bacteria, caused by doing too many low temp washes.
The only permanent solution is to replace the door seal, and at least once a month, do a hot boil wash without clothes in, but with powder or detergent in as normal.
This is called a maintenance wash, and is now recommended by all manufactuers.
Please rate my solution.
Thanks.
Posted on May 13, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Some of my clothing is getting small holes appear ie t shirts and some times jeans i don't over load today it has ripped a towel
There could be several reasons:-
Incorrect use of chlorine bleach
Unfastened zips, buckles hooks or fasteners
Ribs, tears and broken threads
Degradation of material
Hard objects left in pockets
Some sharp foreign object caught in holes in the drum and ripping clothing - feel all around the inside of the drum for sharp objects.
Apr 11, 2011 | Bosch Washing Machines
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
We are getting small holes in our clothes? Is
check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
Aug 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Bosch exxcel 1400 express
unplug the device from the mains for few minutes then check out many a times it clears the fault.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Apr 21, 2008 | Hotpoint WMA44 Front Load Washer
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Hey, Buddy!
Well the mold is caused from the door being shut after you arte finished with the use of the machine. it traps the mouisture inside..To solve this use some bleach and water wipe it down around the door seal..then after each load just crack the door open this will allow air to dry out the inside and stop the mold
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Flakes of dirt on washing
Is this perhaps a second hand machine or it has possibily been stored away for some time? When a washer dries out inside ( behind the washer bowl ) and is then put back in service, dirt from years of use caked on insides flakes away ( like a dry leaf crumbles) and re-enters the wash and can end up on washed clothing. The only way to stop this is complete removal of washer bowl , scrub and clean insides to remove caked on dirt - reassembly. problem fixed !
Jul 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
66 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
