Question about Onkyo TX-SR606 Receiver
How do you get the sound to work when it stopped for no reason. The sound still works for the Blue ray and not for the cable?
  • 25 Answers
Hello Fixya customer,
Thank you for your question,
To further isolate the fault I would need to know what inputs the Blu Ray and cable are connected to.
We want to keep this simple and verify that the inputs are assigned to the correct sources before a hardware fault is considered. Also, you can do a "Clear" of the unit by pushing the "VCR and STBY" buttons at the same time while the unit is on and wait for "Clear" to show in the display.
Caution, if you do a "Clear" the receiver will lose any special setups that you have done.
Thank you for using Fixya, and if I can be of further assistance please let me know.
Posted on May 01, 2010
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
I just hooked up a sony blue ray to Samsung HD TV and it worked initially and now the tv does not get a signal from Blue ray model BDP-S360
Please unplug the Cable from the Blu-ray Player to the TV.
Then, press and hold the STOP button on the Blu-ray Player for more than 10 seconds.
Then, connect the cable from the Blu-ray Player to the TV and check whether it helps.
Feb 21, 2010 | Onkyo TX-SR606 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Nov 27, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Onkyo TX-SR606 Receiver Logo
63 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
