Question about Canon imageRUNNER 7200 Copier
Automatic feeder is pulling multiple
I have canon ir7200 copier and the automatic feeder on top of the machine is pulling multiple pages. What should I do?
  • 1,219 Answers
How many copies do you have? wich type of paper for originals? Some thin or damadged, or small or heavy papers could stuck one to another. Check the specs in user manual.
If nothing above isnt problem clean the rollers and change the separation on adf.
Pls. rate
Posted on May 10, 2010
What is the parts # for a canon ir7200 fixing/feeding unit, where can i get it?
Can you supply more information? Is this a D1 or J1 model Feeder? There should be a plate on the feeder with a Model #.
Jun 07, 2014 | Canon Office Equipment & Supplies
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My Canon Imagerunner 330S feeder usually pulls multiple sheets at a time which stops the copier and requires me to pull the pages back out by force. This problem did not occur for the first several years...
This is usually a simple fix. Most common cause is simply a worn separation pad or roller. What model of document feeder is it? There should be a serial plate on the back of the feeder or under the bottom side down towards where the feeder mounts to the machine. If I get the model then I can list the parts you need. Also is the machine under a maintenance contract? If so then I would make them fix it. Especially if the parts required are available.
Thank You for using Fixya.
WheatlandServices
Jan 24, 2011 | Canon ImageRUNNER 330s Copier
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
FAXING MULTIPLE PAGES
you can use the automatic docu feedr at the top of the machine to fax multiple pages just put all the pages you want to scan on that feeder then do the usual faxing steps
Aug 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Aug 05, 2008 | Office Equipment & Supplies
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Canon imageRUNNER 7200 Copier Logo
127 people viewed this question
old marine
old marine
