Question about Valor Multimedia DTS-603W Car DVD Player
How do you hook up a valor multimedia cd player
  • yadayada
    yadayada May 11, 2010
    using the installation maual.
Is a valor sd900w single din radio compatiable with a backup camera
No, it has no video input from what I can find.
This Single Din Head Unit with a 7" display states that it has an axillary Audio\Video input. It would work with a backup camera.
Feb 09, 2012 | Valor Sd-900w Car Video Player
Tip
Valor ITS-702W units and other Valor Products
<span>Here is the Valor Multimedia website for you to obtain support: <br /><br /><a href="http://www.valormultimedia.com/Support/support.asp">http://www.valormultimedia.com/Support/support.asp</a></span>
on May 23, 2011 | Valor ITS-702W Car DVD Player
Valor multimedia sd-900w wont turn off when car is off
It sounds like you need to connect your red wire to a power source that shuts off with the key. The best way to find a source is with a multimeter to see what wires lose power when the key is off.
Jan 06, 2012 | Valor Multimedia Sd-900w Car Video Player
Valor DDA-650W in car av system Just bought the car it was already hooked up It says Bad disk with DVD's and no disc for Cd's. I'm guessing I should just buy another but I wanted to make sure there was...
You can always try the last resort of a cleaning disk (EX: DvdDr)
That would be your last option as far if it will work again.
Please rate if this helped :)
Mar 09, 2011 | Valor DDA650WT Car DVD Player
Its-703 valor video is disabled for your safety
You have too hook up pink wire to ground wire, that will bypass it
Feb 15, 2011 | Valor ITS-701W Car DVD Player
I have a valor ida700w dvd cd car stereo in my truck and the radio works but the dvd cd player will not play. can you troubleshoot my problem please
FYI..... for any one with a Valor IDA-700w.
The dvd/cd drive assembly was poorly designed.
the clamp that secures disc as it rotates mounts
on one side with a plastic pivot,fine,but the other side
uses a longer metal arm that also has the clamp spring.
The spring exerts too much pressure on the arm and cracks
its plastic anchor.
I repaired mine with JB weld and it plays cds but will not
play dvds,just hunts and hunts or skips.
Oh well,radio plays great-by the way, an undocumented feature
of the unit is that it has a Zoran decoder chip for Dolby Digital
and DTS-too bad drive is inferior.
DTS cd discs play great when it works!
Aug 08, 2010 | Valor IDA-700W Car DVD Player
How do u hook up the ipod to it
you need to purchase a A/V kit for this and hook the kit on the back on the A/V out and that should work..
Please leave positve feedback and ratings for your free answer today
Oct 24, 2009 | Valor Multimedia DTS-603W Car DVD Player
Valor Multimedia DTS-603W Car DVD Player Logo
54 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
hoyzee1
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
