Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
244 wiring diagrams - Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
  • 4 Answers
Sure
Posted on May 04, 2010
This 1982 volvo is popping the fuel pump fuse and i can not find a wiring diagram
I seem to remember that there was a relay for the fuel pump. Remover the wires from the fuel pump. Install a lower rating fuse and see if it. Lows. If it does the. There is a problem with the fuel pump relay or you have a short circuit in your wiring. The. You will. Red a diagram to chase that down. Note rays tend to go open circuit on the co instead of shorting out. If the fuse that is. Lowing is on the power side of the relay whe. The pump is disconnected the. You have a wiring short. If it does not blow with the pump disconnected, it is your pump getting ready to go to the big tank in the sky. Good luck
May 28, 2014 | 1984 Volvo GL
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
My router is displaying the following characters when...
HI ,
  • This is due to which IOS u have Uploaded got corrupted or Flash got Corrupted
  • If you are able to go to ROMMON Mode Please upload the IOS through XMODEM Otherwise
  • Please change the FLASH
Sep 25, 2010 | Cisco (1841) Router (cisco1841)
I WANT TO INSTALL TALLY 9 AND USE IT WITH OUT INTERNET CONNECTION WILL IT BE POSSIBLE. HELP
To activate your license offline follow the steps shown: Go to Gateway of Tally ???? Press F12: Configure > Licensing > Offline > Activate The Activation Form appears ???? Enter the Serial Number in Serial field ???? Enter the Activation Key in Key field ???? Enter the Email ID in E-Mail field ???? Tally displays a message indicating that the tally_req.lic file has been successfully generated. ???? Copy tally_req.lic file available in the Tally folder to a floppy/CD ???? Paste tally_req.lic file to another computer with Internet connectivity and Tally installed. ???? Start Tally ???? Press F12: Configure > Licensing > Offline ???? Select Send External Request to send the request file to Tally Licensing Servers. The response file called tally_resp.lic is generated and saved in in the Tally folder. ???? Copy the tally_resp.lic file to a floppy or CD and paste the file into the Tally folder where the license has to be activated. ???? Start Tally ???? The Register Now screen appears, ???? Press Enter to work on Tallly
important:if this information was helpfull to you please vote for me and write a comment for me.
Sep 02, 2010 | Computers & Internet
I want the wiring diagram for a 1985 volvo 244 dl
Please here to get the wiring diagram...
Good luck...
Feb 24, 2009 | 1990 Volvo 740
1982 244 gl ,searching for wiring diagram!!
Go to amazon.com, alibris.com, or abebooks.com and search for either a shop manual (best) or a Haynes-type guide. both will have wiring diagrams.
If this fails there is a store in Seattle that specializes in auto manuals but is pretty expensive. Paid $25 for an owners manual for my 1982 Volvo diesel, but they had it where no one else does. Don't have name but a Google search should turn it up - go the first route first
Jun 05, 2008 | 1982 Volvo 240 Series
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
251 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
