Question about Gateway FPD1975W 19" LCD Monitor
Monitor starts up then goes blank, like it's going to sleep mode
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 29, 2010
3 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Posted on Feb 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Posted on Apr 17, 2009
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
My monitor on my hp8300 stays in sleep mode
you need to turn off sleep mode its sounds as if its on a timer setting.
Apr 22, 2014 | Samsung Computers & Internet
ASUS monitor won't wake up after going into standby mode
Hi!
You can fixed it using your repair disk.
Or you can restart your computer and then pres the F8 until the start up repair appear.
choose repair or the start up repair.
Jan 26, 2014 | ASUS ML248H 24 inch Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
I have a HP vs17 monitor that keeps going to sleep. It will flash to windows when I first start and immediately goes into sleep mode. When this first happened, I had managed to make sure any sleep modes,...
trixieb1, It's NOT going to sleep mode. Use warranty if possible!! If that not option you will need to read about "cold-cathode-fluorescent-lamps" and the voltage inverters that power them. Learn to do flashlight test when screen goes to black or blank n black!!! Read my fixya profile and those of other ccfl back-lit lcd monitor technicians. We already know what is wrong with your unit. And It is a VERY big problem for all LCD monitor manufacturers. Just do some reading before you do anything else. Good luck with the repair. 12fixlouie
Mar 31, 2010 | HP w2207 Monitor
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor stuck in sleep mode
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Gateway FPD1975W 19" LCD Monitor Logo
263 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
