Question about Mtd 22" Yard Machine Push Mower
Pull string won;t recoil - Mtd 22" Yard Machine Push Mower
  • 3,740 Answers
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Posted on Apr 29, 2010
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Why won't mypull string recoil
when it broke it may have unwound. the spring has to be wound up before it will recoil. you tube has many videos to show you how to rewind the spring. be careful as when wound up it has pressure on it. also be sure to back it off one turn past the string hole so if you pull all the way out it will not break the spring.
Jan 30, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I have a 22in self propelled, how do i change the pull cord
Remove the motor shroud encasing the pull cord assy. What I do is turn the shroud over, leave the spring in it's slack position and gather up the two broken pieces of string. I lay then down in a circular motion on top of the recoil spool until the string is all coiled up, counting each loop made. That and once more is how many times you'll need to wind that spool up. When you are done winding, "round up" to make the hole in the spool meet up with the hole in the recoil housing. Once you're there, get a medium sized flat-head screwdriver and wedge it between the spool and the housing, hindering the spool from unwinding. Wedge it good. Melt the end of the new pull cord and begin outside the housing and feed the string thru the eyelet on the recoil housing. Keep feeding it ( recoil housing still upside down ) thru until you visibly see it pass thru the eyelet and into the hole of the spool. You may need to use a small pick to grab it and pull it home. Once it's out, it's not over. Pull enough string thru to tie a double-loop knot. When you're satisfied with the strength of the knot, reach down and grab the string, holding it tightly. Next reach in and pull the screwdriver loose. Nothing should move-you're holding the string. Hold the shroud with one hand and let the string slowly pay into the recoil spool. Bolt the shroud back on and go!
Sep 23, 2013 | Poulan Pro " Pro" Self Propelled Mower
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
When pulling the string to start the weed eater it feels as it's locked and won't pull out more than an inch I have set it to full choke half choke also primed it nothing works how do I get it...
If this is a 2 cycle engine , which most weed eaters are, then it sounds like probably the piston is locked up inside the cylinder. Try taking the spark plug out. if it still will not pull out then take the recoil cover off. There should only be 4 screws holding it on. Once you get that off see if the string pulls out of recoil if it does then check to see if you can turn the crank on the engine.If the recoil string does not pull over then that needs to be repaired or replaced. If the crank on the engine will not turn over by hand then your engine is siezed. If you take the covers off to expose the exhaust there are 2 bolts that hold it on take those out and look inside. If you see vertical scoring on piston then your machine isnot worth fixing
May 15, 2011 | Garden
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Mtd 22" Yard Machine Push Mower Logo
1,401 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
