Question about Element Electronics EDBCO11 Blu-Ray Player
Did not get firmware disc (cd rom) to run upgrade on new unit
Cannot watch blu ray disc. Need
  • Element Elec... Master
  • 8,457 Answers
The only way is to go to their website to down load.Talk to their customers service.
Posted on Apr 28, 2010
Need a firmware update for Pioneer elite BDP 05FD
The current firmware update for the Pioneer BDP-05FD is available from Pioneer: http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-Disc-Players/BDP-05FD . Click on the Firmware tab then download the .zip file (titled firmware upgrade). Extract the contents of the file.
Burn the .ISO file that is inside the .zip file to a new CD-R (or CD-RW) using your burning software. (If you have Win7, you can use the included burning software to do this. Just right-click on the iso in the file explorer and choose Burn Disc Image.)
Then check that the disc has the needed files and that the files are the correct size: DLfile.pkg 95.3Mbyte (99,942,480byte), .DLdiscidentifier.txt 93byte, DLdiscidentifier.txt 93byte (for v1.71)
Then put the upgrade disc into the player (work with the controls on the front of the player instead of the remote). Then wait until the disc ejects (do not power the unit off or unplug it). Remove the disc and then turn the unit back on. You should see various information show up on the screen that will indicate that the upgrade is in progress. If it doesn't give the prompts, then you may have an unreadable CD. Try burning a new disc at a different write speed (lower); try using a different burner/computer if problems persist.
I hope this helps.
Aug 05, 2011 | Pioneer Televison & Video
Hi. Just purchased TRON Blu-ray and when start playing the disc, it simple blocks when define the disc language (first menu). Exchanged the disc in the store by a new one, but the problem remains....
Yes,by upgading the firmware should help,but make sure the version in ur Blu Ray player and the ugragable version are the same just higher.Because software firmware can put in one time only,if upgraded the wrong software firmware version that it.The Blu Ray player it is garbage,so be very careful what u ugrading ok.
Jun 18, 2011 | Samsung BD-P3600 Blu-Ray Player
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
I have just bought this blu ray player and a new led tv. I have 6 blu ray dvd's and none of them will play. After reading the disc for a few minutes it just says "disc error". i currently do not have any...
It may well be that these Blu Ray are the new generation discs. You may need to download the Firmware upgrade file burn it to a Cd and run it by pressing Play.
Goto LG support site download
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG BD370 BLU RAY PLAYER
SHARP AQUOS WILL NOT PLAY DVD SAYS IT NEED UPGRADE CODE?
Ah, an upgrade. You will need a computer and a disc burner. You need to download the upgrade and burn it to a CD exactly as you are told in the upgrade. Click the link for Sharp firmware.
Most DVDs use a CD to do upgrades. Follow the upgrade detail if this is not so!
Apr 17, 2010 | Sharp AQUOS Blu-ray Disc Player
Will not play bd-rom discs... does the player need any siftware upgrade to play the new version of the rental dvd's?
It is always best to be sure first off that your machine's firmware is up to date. go to sony's websight or your owner's manual, check your firmware status. if not at 5.2, ask sony for its free upgrade cd.
Mar 09, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Gets stuck displayong BD-ROM and won't play
Your Blu-Ray player needs a firmware update from Sony. Here is a link to the page to download the firmware http://esupport.sony.com/US/perl/swu-download.pl?mdl=BDPS300&upd_id=4704&os_id=27
You will need to download the firmware and burn the files to a cd-rom disc. First you double click on the downloaded file to extract the files to a folder. Then you will need to use the "burn image" setting in your cd burning software on your computer and burn those files to a cd-r disc. Then when you insert the disc into the Blu-Ray player it will start the update process. DO NOT DISTURB the player when the upgrade is happening and it usually takes about 30 minutes. Periodic upgrades will be needed with the player to be compatible with the new format of Blu-Ray discs. The full instructions are on the web page.
Nov 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Nov 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Samsung blu ray player
You can download the upgrade from the Samsung site. There are instructions for the entire process as well. Please note that you will need to create an ISO CD for the upgrade.
Dan
Jul 03, 2008 | Audio Players & Recorders
Element Electronics EDBCO11 Blu-Ray Player Logo
206 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
