Question about AOpen 52X32X52X/16X DVD-ROM Combo Drive; MS white bezel RoHS Standard (Lead Free) ( COM5232L-ROHS-M... Burner
Hey my comp was reall slow. its a p4 and so i reinstalled xp. now theres no sound. it says no audio/sound drive. even on control panel or volume no devices are recognsd. iv dwnladed ac3 and dvdshrink coz it also told me to find a compatible dvd converter. this thing has brained me whole day. should i install realtek or an audio driver? i dnt kmw much abt soft wares . pls hellp. thankx
    Guru:
  • 109 Answers
Find out which Audio Device is installed on your PC. According to that download the right driver.
Posted on Apr 29, 2010
Sound card not install
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Aug 03, 2012 | Fujitsu ASUS P5R8L/DP ATI EXPRESS 200 P4...
No audio drver
reinstall drivers
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
hope it helps
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
Apr 24, 2012 | VIA Jetway P4MDPT MB P4 MATX/ P4M266A /...
Ican't playback audio on my Toshiba Satellite A135-S4527 PC Notebook
first ..check teh system driver ..Open the control panel ..and in there look for the sound ..and in this windows look to see if the changes can be made..and the volumes are up .and so ..If it does not allow you to make changes ..or the driver is missing under the devices..it means you need to reinstall the driver ..same this you can check in device manager ..Just click right on computer icon (my comp .for xp ) and select properties and in there select device manager ..(select hardware and after that device manager if you running win .XP) ..In thsi list ..look for teh audio driver and see if it is installed proper ..If it is not ..it will apper with a ask sign and will be yellow marked ..In this case you need to download the driver from the support site ..or use teh drivers disk you got from the seller ..and install the audio driver again ..This should take care of the issue ..
If the driver seam to be ok ..than look at the volume not to be muted..and also the volumes on the volume control to be razed..(volume mixer for windows 7 ) Including the wave volume ..cause if this is down ..it affects the payback ..even if you might have system sounds..
Good luck !
Dec 11, 2011 | Toshiba Satellite A135-S4527 Notebook
Formatted hard drive now i cant get sound
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 07, 2011 | Intel MicroStar MS-6533 P4 mATX...
No audio even i already installed the audio driver
also
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Plz help me to install a sound card driver in window 7
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
hope this helps
Jan 29, 2011 | Intel inside Pentium 4 P4 System Case...
Hey i need help with my asus 945gc motherboard.. no sound?
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 22, 2011 | Computers & Internet
I am getting the error media device not found while installing the sound driver on XP. Please suggest to resolve.th elatop is HP530 with XP sp2
hope this helps
Jan 20, 2011 | Computers & Internet
Wont work on new comp
hope this helps
Jan 12, 2011 | Dell PS-230 Computer Speakers
AOpen 52X32X52X/16X DVD-ROM Combo Drive; MS white bezel RoHS Standard (Lead Free) ( COM5232L-ROHS-M... Burner Logo
89 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
