My Servis M6725 washing machine gradually fills with water even when it is switched off. We have tried changing the inlet valve but it still happens.
    Sergeant:
  • 445 Answers
This is very comon review
decided to buy a Service M6725 machine. I bought one from Argos 'express delivery'. Installed it in a matter of minutes and did a cleaning wash. From then on the machine refused to work. Argos kindly replaced the machine (with the same model) and all seemed fine for a couple of weeks and then for no apparent reason the spin cycle would not perform. Yesterday a Service engineer arrived to 'sort' out the problem. He told me that the no spin was because of an unbalanced load and the machine was working correctly and left me to try more washing. Same result. House full of dripping washing and an angry wife. I am replacing the machine with another brand. ...
Posted on Apr 28, 2010
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
Not filling
http://www.youtube.com/watch?v=_a87KTHws2M
First try turning off the machine for 30 minutes. Re-plug. If nothing happens. Disconnect from mains. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the fine filters on the machine inlet entry, they could be blocked, clean out. The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem. There is a slim tube going up from the filter area to a switch near your control board or panel; it leads to the pressure switch - it should not be blocked or leaky - ie.with holes.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on some washers.
Inlet valves can be purchased thru searching this site and fitted by you easily.
Just noted that your machine is a top load; anyways, click if helped.
Apr 24, 2013 | Hoover HTC243 Top Load Washer
My servis automatic 900 model m3094 fills up but does nothing else
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 07, 2013 | Washing Machines
The water stopped coming into the machine?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water fills the tub even when machine is not
This is almost definatley the inlet valve faulty.The inlet valve is literally stuck in the open position.You will need to change the inlet valve.I hope this helped you.
Jun 01, 2010 | Washing Machines
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Jun 22, 2007 | Creda W100FW Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
