Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
One new battery after another
Every time I put a new battery in my riding lawn mower it is completly drained the next day. I can't figure out what is causing it. The key is turned all the way off, and there are no lights or anything left on. Can you please help me with this?
  • 718 Answers
Sounds like there is a short in your system and that is what is draining your battery. If you are not handy with a volt meter or troubleshooting have a service center in your area look at it, it could be something as simple as a loose wire, these machines have a lot of vibrations when running. Good Luck
Posted on Apr 29, 2010
Dead battery in cub cadet riding lawn mower
sounds like the stater is not charging. check connections if that don't fix it test to see if stater is charging
Jun 14, 2016 | Cub Cadet 2012 - LTX1042 KW - 42 Inch Lawn...
Riding lawn mower battery won't hold a charge
It is a battary issue, however it sounds like the engine is not charging the battary so it goes flat, or there is a drain on the battary .
Jun 27, 2013 | Craftsman Garden
I don't kown anything about charging batteries! How do I carge a battery in a 2008 Husqvarna riding lawn more?
mille get yourself a cooler and put 8 cold beers in it. Put that cooler into the gap between the seat and the "dash" of the mower. Make sure your gas and oil are good. Have someone jump start your mower from a car and then you mow and drink and mow and drink until the beer is all gone. If the mower does not start from the battery the next day go out and buy yourself a new battery. If the battery and charging system are good then you do not have to charge it if it is being used regularly.
Apr 20, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My Bolens riding lawn mower wouldn't start.
I will attempt to help you figure this out. On a sidenote; the shop I work at offers pick up and delivery services, Im sure a shop near you would too.
First make sure you have good fuel in the tank and that any fuel valves are open, check your oil and make sure it is full. If your oil is overfull and very thin and runny that could be an indication of your problem. REmove the airbox cover and air filter.
Once we've covered that lets get on with diagnosing it. Will the motor turn over but it just wont start? Does the motor make a half crank then stop? Will it not do anything at all?
Answers to those questions and any other pertinent information will help me guide you in a direction to figuring out the problem. Figuring these things out is simple if you take it step by step.
Dec 29, 2009 | Garden
Riding Mower will not start
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Jul 05, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
183 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
