Question about Amana NTW4500V Washer
Inside of washer smells bad!!
The inside drum of my washer smells musky... tried pouring straight bleach into the washer with no water let set half hour then spun that out and rinse cycled it still there... also tried straight hot water with half box of baking soda, neither worked! the clothes dont smell coming out but the washer is grosse! plz help
  • v_nger Apr 29, 2010
    under the entire washer?? this washer has no bottom to it and there is no sign of leakage or smell under washer itself.
  • 10,319 Answers
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Posted on Apr 29, 2010
  • frank thomas wilson
    frank thomas wilson Apr 29, 2010
    The smell is inside the washer were the motor and transmission is located. The hoses have clamps which tend to put pressure on the very thin hoses causing them to leak very small amounts of water. In time the water will hold mildew and start to smell. The washer does have a bottom to it and will hold any moister and the foul order as well
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
The clothes smell like meldew even thought they just finished washing even tried to switch cycles to hot water ? why
Thanks for choosing FixYa and welcome to the site. More then likely, the washer needs cleaned out. Articles of clothing and other items get caught in areas of the washer. Over time, the wet clothes and items will cause a fowl smell. You need to check these areas and make sure you clean them out. The bottom tub is where you should check. After you remove them, run a load or two of bleach water. It would be wise to clean the washer with a disinfectant as well. If nothing is seen, it is possible to have mold. Especially if you smell a musky odor, rather then just a stinch. Anywhere the water goes has the opportunity to hold mold. Check the water pump and the hoses also.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer smells musty
there could be buildup in the outer tub causing some water to stay trapped and causing the smell, try running some loads uning Ahfresh or you can try pouring lots of bleach in there and letting it sit a while, then run it throu a cycle.
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Smelly Water Draining
Try getting the new whirlpool affresh washer tablets. They clean the mold and are supposed to make everything in the washer smell better and keep it clean. They are only around 10 bucks and is worth a shot to clean your smelly drain.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Strong mold smell inside washer
Powder is tuff on a front loader, liquid is the way to go. One solution is to use a ratio of 2 Tbls of soap to 1 Tbls of softener as this machine uses 70% less water and this makes the solution of soap much stronger causing a build in the back bottom of the tub. Every one I have rebuilt has had to be scrapped out because of excess soap, liquid or powder. This stuff turns black and is awful. I usually use washer magic only and knowing that one use will not remove even 3 years of build up but is a process of reversing the junk. So I will by one from Walmart for about 4 bucks and pour the contents into the machine will empty of clothes and water and let it sit over night to start breaking the stuff down, then in the morning I will run hot water in the closet sink to the machine so when I start the cycle the water is hot. So after soaking you want hot water with a heavy agitation plus a second rinse and that will remove half of the junk. I usually do this every month on my top loader because of hard water and my clothes do smell much better for it
Sep 20, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washer smells bad
There is a door on the bottom og this machine, I opened the door to find a little spot, I placed a bowel under the spout and opened it, drained all of the liquid out and this problem stopped! I also ran the machine on hot water with bleach after I emptied this resevoir. How often you do laundry will determine how often you must empty it. For me, once every 6-8 months does the trick!
Dec 08, 2007 | LG WM-2277HW Front Load Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Amana NTW4500V Washer Logo
438 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
