Question about Jl Audio 500/1 Car Audio Amplifier
Installin car systems
"how to install car system with 2/1 channel alpine MRPT220 connect to a JL Audio 500/1 amp"
  • Bobinger79 May 11, 2010
    To be honest, I don't really understand your question. Please clarify that.
    Problem Solver:
  • 7 Answers
You dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Posted on Aug 08, 2010
JL Amp isn't powering subs and speakers
just go through ur connections man one by one ull find the prob soon.....check teminals on battery...power line to amp ....all fuses within prob area and obviously make sure u have a good ground.....really impotant.....ground is the most neglected thing people do from my experience bein a audio tech oh and if that isnt it check ur subs....stick a 9v batt on the back pos n neg of each sub n c if they pop in r out this will determine if ur subz r blown
May 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Low ohm light on 500/5 front left channel doesn't work.
The first thing is to meter all the speakers with a volt/ohm meter. They should read somewhere between 2-6 ohms. If they meter good try swapping the RCA's and see if there is any difference. But if both of those check out ok than. Unfortunately it would appear that your amp has a bad output channel. What seems to happen is that when the amp is cycled off and on, off and on etc. the solder on the PCB can get brittle causing problems. The only answer i can offer is to send it to JL to repair or find a good repair shop that works on car audio amps. It's getting harder to find a good tech but they are out there. If you send it to JL they have a set repair rate of $180.00 which covers the return postage while the customer pays the shipping cost getting it there. They do an excellent job and pretty much go thru the whole board and replace not only what is wrong but will also perform any mods or changes since date of manufacture.
Aug 12, 2009 | Jl Audio 500/5 Car Audio Amplifier
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 500/1 Car Audio Amplifier Logo
128 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
