Question about Kenmore 57029 Side by Side Refrigerator
The temp alarm is sounding
The temp alarm is going off. The temperature is rising. This happend last week and I emptied the fridge and it happened to fix itself and returned to the normal temperatures ( frige and freezer). It is doing the same thing now....temp alarm going off and the temp ( frige and freezer) are going slowly up.
  • 3 Answers
Sound to me it is going into defrost
that model has electronic controls that will need replacing defrost adapt board
Posted on Dec 21, 2010
    Sergeant:
  • Kenmore Expert
  • 448 Answers
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Posted on Apr 28, 2010
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
The temperature on my Heartland refrigerator fluctuate between 34 deg and 50 deg, is this normal?
How long does this temperature issue last? When you notice this issue how long does this sit at the hire temp, 1 hour? I am trying to understand why Heartland/Marvel would ask you to turn it off. Please let me know. Thanks
Aug 01, 2014 | Heartland Refrigerators
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
ELSE
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Carnac the Magnificent
Jul 28, 2017 | Fisher Refrigerators
I have a Whirlpool MFI2266AES and few days ago the ice/water dispenser stopped working. At the same time the freezer temprature started to rise and the temp alarm started beeping. The freezer fan was...
Hi, it sounds like your having problems with the thermostat ,they don't last for ever. I had the same problem with a fridge freezer and i got the temp thermostat replaced. You have a modern unit and you may have two but i think you have to look at the ice cube maker side first. Check that the water supply is getting to it.Have a look at your manual or you can type in the make and model and look up online .
Mar 06, 2014 | Maytag Refrigerators
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
584 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
