Question about Kenmore 63942 Dryer
How do i access heating element to kenmore electric dryer
How to access heating element for kenmore dryer
    Sergeant:
  • Kenmore Expert
  • 448 Answers
Send a model # to appliancesplus.net
the step ya thru it
Posted on Apr 28, 2010
Kenmore 110.82822102 Electric Dryer runs but no heat.
I think the heating element went bad. Depending on your driers layout, you might have to remove the drum assembly to gain access to the heating element. Once drier drum assembly is removed, check and see if there is 220 volts going to the heating element. If there is, heating element is bad, if no voltage detected, the switch in the control panel is faulty. If you're not comfortable trying to check this out on your next step, I don't blame you. A qualified appliance technician would be the better answer especially working around 220 volts. Hope this works out for you.
Mar 10, 2014 | Kenmore 83142 Electric Dryer
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
He3 electric dryer : no heat
Heater Element needs to replaced. Accessing from the back panel.
Jan 09, 2010 | Kenmore 82822 Electric Dryer
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elec Dryer Won't Heat up
Sounds like either a faulty thermostat or heating element. Both are accessed from the lower right backside of the dryer behind a metal door. Be CAUTIOUS, the edges can be sharp and cut you very easily. Good luck.
Mar 23, 2008 | Kenmore 65924 Electric Dryer
Kenmore 63942 Dryer Logo
169 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
