Question about Sony KV-32S25 32" TV
I have sony kv-32s25 powers on but no picture i do have sound and the stand by light is flashing and idea's
  • mike4159 Apr 28, 2010
    the count is 1 per sec if it where in morse code it would be - - - - - - - - - - - 60 times per minute
  • 70 Answers
Open back case, move screen control on flyback clockwise just a bit and the picture should come back. this is the lower one on flyback.
Posted on Apr 28, 2010
Testimonial: "thanks guys super fast responce "
  • atelier mj
    atelier mj Apr 29, 2010
    do you try to turn the screen control clockwise?
  • rarriaga63
    rarriaga63 Jul 13, 2012
    Hello, I also have the same TV with same symptoms, I already tried adjusting the flyback, but it did not work. I already retouched a good number of solder joints on the main board..... any more tips ?
    Thanks
  • 4,234 Answers
The key here is the standby light flashing. It should be flashing in a repeated count of flashes with a pause inbetween. Count the blinks and report that number here. This is a diagnostic code indicating the circuit that is having a problem. Armed with that info, we should be able to give you an idea of the problem and its solution.
Thanks,
Dan
Testimonial: "thanks guys and so fast i'm talknig minutes "
    Sergeant:
    Champion:
  • 246 Answers
It seems that your TV has no horizontal (picture) at the moment. The best solution for this is reservicing the whole unit by resoldering the main board. Mostly heated areas, for dry joints, near Vertical IC, CRT board. The last thing is to change the Horizontal IC.
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
My Sony 32" inch has power, but no picture. When it is on the Standy/Timer light just blinks.
May be its Timer ON/ Off function is ON. Bring it back to the normal mode. Reffer User manuel.
Sep 11, 2009 | Sony KV-32S25 32" TV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony KV-32S25 32"
Check Horiz. output transistor = shorted?
1)replace with first quality transistor
2)solder horiz driver circuitry
3)replace shorted converter transistors (2SC4834)
4)Replace open R607 .1 ohm 1/2 w.fusible (resistor ok)
   test.......T.
Oct 25, 2007 | Sony KV-32S25 32" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony KV-32S25 loss of picture and sound
The set might have loose conections in the horizontal drive circuit and other overheated places in the power supply,dont use the set like that or it wii die completly and it will be more expensive.Call a technician so he can resoldered all the bad and questionable solder conections.Be safe and let a proffessional do it.Good day.
Sep 13, 2006 | Sony KV-32S25 32" TV
TV keeps flashing on/off
Is the picture coming and disappearing? Or is it that the TV is switching ON and then OFF? And what about the sound? Please provide more details.
Aug 28, 2006 | Sony KV-32S35 32" TV
Televison & Video Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
