Question about 2wire 2700HG-B Router (2700HGB)
Home network with 2700hg-b and netgear wireless issues
I have been able to set up internet connectivity with the 2 wire attached to my host computer and netgear to my client. i can access internet with both computers. i cannot however share printers, files... blah blah. what is wrong?
  • freedomis Mar 24, 2008
    I have the 2700 in my ofice which is connected via ethernet to the main PC and wireless to two laptops. Although the 2700 can see all the PCs in the newtork, and all PCs can access the internet OK, we cannot file share between PCs. Also, we cannot ping from one PC to another. It would appear that the 2700 is not allowing VPN traffic (private network) to flow through it. Interogating the 2700 system setup does not appear to help.
    Problem Solver:
  • 16 Answers
You didn't say what operating system you have but check your Network and Sharing Center in Control panel and turn on the file and printer sharing feature in Windows.
Using Vista, click on Control Panel- Click on Network and Sharing Center-configure settings.
Hope this helps.
Posted on Mar 25, 2008
SOURCE:
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
Wifi works and all but keeps having my two phones put the password in every half and hour. I don't have the disc for it so can't really set it up just connected it to my charter modem.
Try this please:
  1. eHow
  2. Internet
  3. Wireless Internet & Network Hardware
  4. Netgear Wireless Routers
  5. How to Access Netgear Wireless Router Settings
X Must See: Slide Shows
How to Access Netgear Wireless Router Settings Xno-user-image.gif Ryan Bauer
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
72955587_xs.jpg Wireless routers connect computers to a network without the need for network cables.
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryptionicon1.png," "Network setup details" and "Passwords" can be customized.
Other People Are Reading
Instructions
    • 1
      On a computer that is connected to the routericon1.png with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    • 2
      Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
    • 3
      Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
Read more: How to Access Netgear Wireless Router Settings ' eHow.com http://www.ehow.com/how_4913660_access-netgear-wireless-router-settings.html#ixzz2H3QQJGxn
Jan 04, 2013 | Computers & Internet
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Can connect to internet via cable but not wirelessly with netgear router
I understand that you are not able to connect wirelessly through the router DG834G. Please perform the below task to configure the required settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
Please scan for the wireless network on your wireless enabled computer and connect to the network of the router using the security key as mentioned above. If the issue persists, then please let me know about the operating system installed on the wireless computers.
I hope this information allows you to resolve this issue. Please revert back for any more assistance on the same.
Regards
Anand
Mar 24, 2011 | NetGear DG834G Router
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
2005 FORD F150 AC blows cool/warm in front and cold n back vents
Check i the truck comes with separte a/c units, if the front is warm check for an open heater valve, if ok, check for proper gas pressure.
Jul 08, 2009 | 2005 Ford F-150
The camcorder doesnt reset anything. The mini DV still stuck in
Networking Configuration A network architecture is a set of standards for how computers are physically connected and how signals are passed between hosts. Some typical network architectures are described in the table below.
Network Architecture Description Ethernet Ethernet is a wired networking standard and is the most common networking architecture used in LANs (both in business and home networks). Dial-up Modem Dial-up networking is a common way to connect a computer (often your home computer) to a remote network, such as the Internet or a business network. A modem on each computer uses the phone lines to send and receive data. DSL (Digital Subscriber Line) DSL is a fast-growing alternative to dial-up networking to connect to the Internet. DSL uses regular phone lines to send digital broadband signals. ISDN (Integrated Services Digital Network) ISDN is another alternative to traditional dial-up that can be used to connect to the Internet or to directly communicate with another computer connected to the ISDN network. ISDN is more common in Europe than in the U.S. ISDN can use regular telephone wiring, but must be connected to a special ISDN network. Wireless Wireless networking uses radio waves or infrared light (with the air as the transmission medium) to send data between hosts. Wireless networks are common in homes, businesses, airports, and hotels. Most wireless networks connect into larger wired networks (such as LANs) which are in turn connected to the Internet. Communication between hosts on a network generally takes one of three forms:
  • Simplex--one-way communication from a sender to a receiver.
  • Half-duplex--two-way communication between two hosts. Communication only travels in one direction at a time.
  • Duplex--two-way communication between hosts. Communication can travel in both directions simultaneously.
Jul 08, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
2wire 2700HG-B Router (2700HGB) Logo
161 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
