Question about Canon PIXMA MP600 all-In-One InkJet Printer
It makes a clacking sound and will not print - Canon PIXMA MP600 all-In-One InkJet Printer
  • 4,041 Answers
Hello there Could be some thng sticking.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
When trying to start car the the voltage drop to 0. And the starter makes a clacking sound. What could it be ?
Voltage 0 check Alternator or Dynamo Clacking sound on starter , sound thst is does not fully disengage from engine when you start Car
Mar 14, 2015 | 2001 Mitsubishi Mirage ES
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
HELP Clack Clack sound when starting my Ford Explorer
If its a rapid clack time then it could be the battery terminals need to be cleaned, it could also be the starter solenoid mounted on the fire wall has loose nuts corroded or the ignition wire from the key switch the round connector can wear out and not make contact. So check those things first if you have a test light I can give you the procedure to test the cables and solenoid.
Oct 10, 2009 | Hyundai Motor 2004 Accent
Clacking noise at different engine idles on my Yamaha V Star
Lots of bikes make a clacking in the transmission , especially when cold at idle. Basically the engine accelerates and decelerates between each piston firing, and you hear the backlash in the gears slapping back and forth. Without hearing it I can't say for sure, but find someone else with a similar bike and see if it sounds the same.
Sep 23, 2009 | 2002 Harley Davidson XL 1200 S Sportster...
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Apr 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Canon PIXMA MP600 all-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
