Question about Zanussi TD4112W Electric Dryer
No heat drum turns on td4212w
No heat drum turns on td4212w zanussi tuble dryer
  • Zanussi Master
  • 43,501 Answers
If you have a gas dryerno heat drum turns  on td4212w - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is eleno heat drum turns on td4212w - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" />..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 29, 2010
Why does my Zanussi td4212w tumble dryer work but no heat?
check continueiy in the ellement and the thermostat
check the thermo with out 1 wire on........cheers
Jul 18, 2014 | Zanussi Dryers
Where is the heater element in Zanussi td 421
They are under the drum in a metal box that is connected to a heater hose and wires. Make sure you unplug it before you work on it. Note the location of the wires that connect to it and also there is a thermal fuse and thermostat that are hooked to the box. Check those too.
Aug 10, 2012 | Zanussi TD4212W Electric Dryer
The drum fails to start spinning, a humming sound is emitted. there is black residue around the idler pulley, but the belt seems o.k.
There might be a problem to the starting capacitor of your drier. Check the capacitor if it is working or not.
Nov 01, 2010 | Zanussi TD4212W Electric Dryer
The Dryer is no longer producing hot air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Zanussi TD4212W Electric Dryer
Tumble dryer 4212 no heat where are thermostats
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps.
Jul 18, 2010 | Zanussi TD4212W Electric Dryer
My dryer is not shutting off/no heat
The cycle timer motor is bad. Easily replaced and you can do it yourself. Does the dryer normally heat when drying?
Sep 14, 2009 | Zanussi TD4212W Electric Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
MAYTAG DRYER DE-306 REPLACING HEATER ELEMENT
the elament is in center of drum take off back of drum
Feb 18, 2009 | Zanussi TD4212W Electric Dryer
ZANUSSI TD4212W drum does'nt turn, heat works any ideas?
with top off and machine in operation, try giving the drum a push by hand. if it starts to rotate and continues to rotate, then the fault is with the motor capacitor - cheap part
and of course, with the top off, check the belt is in position and not broken
Sep 09, 2008 | Zanussi Dryers
Unit not drying properly
I suggest you pull out your lint trap and inspect it and where it fits for a blockage. Also check the vent for any blockage. Then take out the lint trap and run it under cold water. If it holds water, wash it with warm water and soap then throw away your dryer sheets.
Aug 22, 2007 | Zanussi TD4212W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
103 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
