Question about Maytag Bravos MTW6600T Top Load Washer
MTW5870TW matag washer
How do i flip the top console to access the timer??
    Sergeant:
  • Maytag Expert
  • 448 Answers
Putty knife front of control panelbetween top of washer and control console (plastic) metal clips need pushed in twards back of unit top will hinge back they may spring off so watch wear they fly
Posted on Apr 28, 2010
Testimonial: "great help---thanks"
  • 299 Answers
Remove screws on the rear. The console is held by two clips found under the lid above tub. Release the clips to remove the console.
How to change the timer on WGD5800SW0
First things first, disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the screws attaching the console to the rear of the machine then use a putty knife blade or similar tool to push and release the clips holding the console in place to the top of the machine. Push the putty knife blade rearward under the front corners of the console until the clips are released. Pull the timer knob off then flip the console to access the timer.
Remove the screws securing the timer to the console bracket then secure the new timer in place. Disconnect the wires from the old timer one at a time then connect it to the new timer to prevent messing up the wires.
Push down the console down onto the top of the machine to engage the clips then secure the console back into position.
Note: The timer is part number 3406725.
May 22, 2010 | Whirlpool WGD5800S Dryer
Maytag washer mtw5870tw , washer works but i have to manually click it out of the wash cycle-- timer , timer motor??
Yes, generally they both come as an assembly together. I reccommend change the timer assembly.
Mar 15, 2010 | Washing Machines
Maytag Neptune washer shutting off in mid cycle
It must be the timer that is causing the control board or "computer", as you call it, to shut the cycle down, especially when the machine shuts off at almost exactly the same point in the cycle. The control board energizes the timer motor and monitors changes in the timer inputs. It will open the power supply line relay and shut off the machine if the timer inputs do not change within 5 minutes of continuously energizing the timer motor. It means the timer motor is stuck or the timer internal cam is broken at the point where the machine shuts off. Replace the timer (part #22002867) to fix the problem.
Disconnect power to the washer and remove the three screws securing the console's rear cover plate across the console's rear top edge.
The console has six locking feet that secure it to the top cover. Gently rock the top of the console forward then push the bottom of the console toward the back of the machine to release the locking feet from the slots on the top cover. Once the locking feet are released, remove the timer knob by pulling it off the console; lift the console then flip it forward onto the top cover to access the timer.
Disconnect the timer wiring harness then remove the timer mounting screw.
Lift the timer locking tab near the end cap and slide the timer toward the end cap to release the timer retaining tabs from the slots in the console. Lift the timer off the console then install the new timer.
Align the three tabs of the timer with the slots on the console then insert the tabs into the slots.
Lift the locking tab slightly then slide the timer back into position until the locking tab can engage with the slot provided in the console. Secure the timer with the mounting screw then reconnect the wiring harness.
Reinstall the console by lining up its six locking feet with the slots on the top cover. Insert the locking feet into the slots then rock back the console into position. Secure the console's rear cover plate across the console's rear top edge with three securing screws.
Mar 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
Feb 17, 2009 | Whirlpool WTW5800SW
Whirlpool Ultimate Care II Timer Problem?
ok if you look at the back corners on the back of console,,on each side you will see a screw in recess it a phillips head,,just remove these 2 screws 1 on each side ..than flip the console back towards the back of unit..replace timer...onthejob
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you get the timer off a maytag atlantis toploader?
first unplug unit,,remove the three top screws across backof console..now on timer knob remove the outer most cap or the center cap..remove the clip,,carefulf now theres a spring behind knob dont let it fly ,,remove dail...good,,,noew go back to console and flip it down top towaeds you bottom away,,jiggle just a touch now your in,,remove 2 timer screws from front ,,reverse to to put together...onthejob
Dec 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite, Quiet Pak II Top Loading Washer
there should be 2 screw on the left and right side of the console. remove the screws and the console flips back so you can get to the timer. youll have to remove the knob and dial from timer too to get to the screws that hold the timer in place. if you dont have a local appliance parts store in your area then you can order the timer at sears.com and theyll ship it to your house
Nov 24, 2007 | Kenmore 15944 Top Load Washer
Washer won't cycle
Sarah, it sure could be the timer. If you start a cycle, it fills, starts agitating but the timer does not advance after that, it's probabley the timer motor. You want to make sure that this is happening on all cycles and cycle speeds. Have someone pull off the consol end caps, (they just pull off) remove the two screws and flip the consol up. Make sure the harness to the timer is seated. The part number for your timer is. 8557393. Catriver..post back.
Feb 10, 2007 | Kenmore 15864/15862 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
241 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
