Question about Kenmore 98702 Stacked Washer/Dryer
Very loud banging and clanking when the drum is spinning
  • 10,319 Answers
If the dryer is making this noise the roller on the belt tensioner has a flat spot causing this to happen. The roller and belt are replaced as a unit. If it is the washer unit the spring has fallen off on one side of the drum which is one of two that balances the drun while spinning
Posted on Apr 29, 2010
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Sep 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
234 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
