Question about Dishwashers
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
My dishwasher seems like it runs, except no water is coming out. I'm not sure how to take the filter that is at the bottom out, or to see if there is a blockage in the line.
Thanks for any help you can offer.
Dishwasher is just under 10 years old. Not overly used for its years.
  • 1 more comment
  • ajknight May 16, 2008
    i have the same problem, just put it all back together after making sure that it has water...everything checks out fine, it gets hot and makes the sounds like it is running all through the cycles.
  • sdlang Oct 12, 2008
    We are having the same problem.  Sounds like it is running but when I open door no water is on the dishes or on the bottom of the dishwasher.  Please someone HELP!
  • Anonymous Nov 07, 2008
    same
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Posted on Apr 30, 2009
  • keller02135 Feb 12, 2011
    I had no water coming in to my dishwasher. Filled the bottom of the tub with very hot water as suggested, worked like a charm, almost immediately. Thanks.
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Kenmore dishwasher and recently it seems to have stopped pumping the water, as in stopped spraying the water. It still sounds the same and runs through the cycles but it seems to only steam the...
water not getting to the unit as they should be or your pump is clog with left over you will need to take the spray arm out and get to the pump and clean it.
watch for broken glass!!!
Sep 30, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The dishwasher sounds like it's running but there doesn't seem to be any water coming through.
ANTI FLOOD ATIVATED APPLIANCE WILL ONLY OPERATE DRAIN PUMP IF IT CONTINUES WITH DOOR OPEN THEN THATS THE PROBLEM TRY REMOVING MACHINE AND TIPPING BACK IF WATER LEAKS ONTO FLOOR A LEAK WILL HAVE CAUSED THE FAULT TRY RUNNING IT SEE IF IT REPEATS THE FAULT IF IT DOES WILL NEED SERVICE TECH TO FIND LEAK
Sep 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a miele G646 dishwasher whihs has sprung a leak into the bottom tray. Have dried it up and reset float switch but the water seems to be coming from a pipe on the left hand side of the machine. i...
It sounds like the leak is coming from the water intake hose.
The water intake house is located at the bottom sump of the dishwasher. To get to it the dishwasher has to be taken out and put on its back and the floor plan needs to come off. The intake hose runs from the inlet valve under your sink and attaches to the sump with a metal keeper. Overtime the part of the hose where the keeper is cracks (Normal wear and tear). As I recall the intake hose runs approx. $129.99 from Miele direct. It comes with an inlet valve on the hose. there is no separate or substitute hose you can use.
Good luck
Sep 12, 2009 | Miele Incognito G858SCVi Built-in...
The pipes froze in my house and now the dishwasher seems to work (ie it all sounds fine and water is in it), BUT it leaks badly. viking model vud140.
If the temperature dropped in the home too the water retained within the pump and the units lower assembly may froze which may have cracked which woul leak heavily. It mat be by chance too that the seal within the pump has failed. If it leaks only when the pump runs chances are the seal may be out; if however it leaks with nothing running it may be a crack. Another spot to check is the fill solenoid. You need to get underneath it or pull it out to determine where the leak is coming from.
I hope this may have helped,
Tom
Aug 22, 2009 | Viking Dishwashers
I have a Zanussi Fitted dishwasher and I notice that the board under my kitchen seems to be getting black,I think it is the dishwasher leaking water from underneath.. Is there any common problems with this...
Yes sounds like some kind of water leak. Take of the front plinth and check underneath the units and DW. I presume you DW is adjacent to the sink so please cheak all pipes including waste asap. Also opening the DW door whilst it is running can splash water, over a period of time this could effect wood material and cause your problem.
Mar 09, 2009 | Zanussi ZT485 Built-in Dishwasher
Dishwasher's cycle just stalls
It looks like you have a cold water supply problem. Check water entrance pipe, may be bend (if you have there a vane - see it is open).
Check that water entrance valve work (it is an electromagnet valve,located at the pipe's enterance to the machine).
If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnected the power cable from machine before doing it.
Check as well for valve's coil resistance or you should replace for a new valve.
Feb 17, 2008 | Electrolux 24 in. EDW5500DSS Stainless...
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
3,164 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
