Question about Samsung LTN226W 22 in. HD-Ready LCD Television
When I turn my tv on I get a static noise that lasts about 5 minutes that eventually goes away. Even if I turn the volume all the way down on the TV the noise level does not change.
    Sergeant:
    Champion:
  • 246 Answers
It seems that the high voltage is leaking, or it might have some capacitors which are also leaking. I order to repair this problem, you should contact a qualified technician. Check all the basic connection, also for the earth (grounding).
Posted on Apr 28, 2010
Testimonial: "Thank you very much. Appreciate the prompt reply to the issue. I will get a professional to look at it. Cheaper than buying a new one I hope."
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
Y Component Cable Related - Internal Static Noise
It sounds like one of those cables has a defective ground. The static noise you are experiencing is cause by the cables not inside the TV. Try using different cables to isolate the problem and get new ones.
Good Luck.
Feb 17, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Occasionally the right channel gets a lot of static
If the noise goes away when you turn down the volume, it means that it starts before the volume control. And if the volume control has no effect then it is the stage after the control.
Transistors, IC's, bias resistors or ceramic capacitors can cause noise.
If you heat up a transistor by touching it with an soldering iron, it might cause the problem to start up. If it does you have found the culprit. You can also try spraying them with Servisol freezer spray which can be got from Maplin UK or Radio Shack USA. This will cool down any part and help detect the faulty ones.
Aug 03, 2009 | Adcom GFA-5500 2-Channel Amplifier
Loud static Noise
that sertainly doesn't sound normal to me
Jul 29, 2009 | Televison & Video
What causes the static background noise in my keyboard?
It sounds as though you have a static electricity problem in your volume pot. Although there are sprays on the market that you can use for all of the electrical switches on your keyboard which removes and suppresses static electricity, one way to make sure this is the problem is to slide your volume slider to maximum, then minimum, up and down about 10 to 20 times, if the scratchy sound begins to diminish, you knwo the problem lies there. As a matter of fact, if you do it long enough, the sound may go away altogether, although without a good spray of electronics cleaner or electrical contact cleaner (which you can find at stores like home depot or online, even eBay), the sound will return.
If this is not the case, and the scratchy static sound does not go away or depreciate, it could be your cords or even static on the pc board inside the unit. If you are confident that you can crack the case on your board without causign damage, then get a screwdriver and open the case (all screws are located on teh bottom of the unit) and give it a good spraying with electrical contact cleaner on all of the contacts and even a once over on all of the circuit boards. Do not wet the circuit boards with too much spray, rather, give them a light misting.
For areas where you plug in, like your 1/4 inputs, your midi ins and outs, and headphone jack, spray the contact cleaner inside the holes. You don't have to worry about spraying too much in these areas. Just do not oversaturate.
Hope this helps, and thanks for using FixYa
Jul 18, 2009 | Music
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Sound
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Mar 03, 2008 | Sony KV-27V42 27" TV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Samsung LTN226W 22 in. HD-Ready LCD Television Logo
231 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
