Drive belt keeps coming off - Washing Machines
  • 10,319 Answers
The belt is stretched out of shape and needs to be replaced
Posted on Apr 29, 2010
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
Why after fitting a new belt on my hrx476 mower does it still keep coming off
Make sure the belt is in line and the idler pulleys are free and not seized and check the adjustment is correct might be the back axle is slotted for the adjustment.
Mar 29, 2016 | Garden
The drive belt keep coming off. New mower had another one the same problem took it back and exchanged it for this one 42in mustang
If your drive belt comes off, it's usually a sign of either the belt isn't right, too long... OR the belt guides are either missing or installed incorrectly. There should be guides next to each pulley which keeps the belt close so that when the blades are disengaged and loose, they won't flip off once activated
Nov 05, 2015 | Mustang Garden
2002 Pontiac Bonneville supercharger. Why does one of the belts keep coming off?
Check all the pulleys on that belt. One is bad. Oil doesn't help, but shouldn't be the problem of the belt coming off.
May 02, 2015 | Pontiac Cars & Trucks
Why does cub cadet lt 1024 drive belt keep coming off belt
Once the drive belt comes off once - it's probably stretched and twisted and won't stay on. You'll need a new belt - be sure to get one that's Kevlar so you won't be replacing as often.
May 03, 2014 | Cub Cadet Garden
Seat belt keeps buzzing
Check wiring to the seat belt. Could be broken/touching and sending wrong signal to relay
Nov 30, 2012 | 2005 Seat Altea 1.9
Drive belt keeps slipping off when clutch is pushed in
when you replaced the belt did you put the tabs bad into place that keep it from coming off the pulleys?is there a bad pulley?
May 29, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Battery Light comes on while driving, It seems to come on and then go off, but it comes on with accelleration. I have replaced the battery and cables. Don't know what to do? Help please
CHECK ALTERNATOR DRIVE BELT TENSION IF BELT LOOK LOOSE ADJUST DRIVE BELT TENSION.IF YOU HAVE AUTOMATIC BELT TENSIONER CHECK FOR FOR BROKEN BELT TENSIONER. IF DRIVE BELT LOOK OKAY.CHECK ALTERNATOR VOLTAGE OUT PUT AT BATTERY WHILE ENGINE IDLING.BATTERY VOLTAGE SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR FAULTY.FIRST CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR POWER FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE OR LOOSE CONNECTIONS. FIRST TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
Sep 02, 2011 | 2000 Mazda MPV
A belt keeps slipping off and the power steering no longer works.
Check to see that no bolts or mounting brackets are loose causing the power steering pump to be out of alignment with the rest of the pulleys. When replacing the belt make sure it is seated correctly on the pulley because if it is one ridge off it will cause the belt to shred very quickly.
Feb 25, 2011 | 2000 Chrysler Town & Country
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
