Question about Vizio L37 Television
Vizio model L37
I have replaced the main board in the tv but still no picture or sound.I just have the green power light on and the screen is totally black.Any other board that you think it could be?.Thanks pcrane1
  • pcrane1 Mar 25, 2008
    I tried the troubleshooting guide .I did notice though for the first time a real faint thumping sound in the sound.I havent noticed it before. I have noticed that when the tv is turned on the light goes green of course and a red led light comes on and then goes off.This led red light is located on the board right above it.The board #is 3550s-0250a.I dont know if this is normal or it could indicate something.
    Thanks
  • 3,037 Answers
Here, try the trouble shooting guide and let me know start with page 56, here is the link
Let me know when you have tried the trouble shooting for picture and sound even though this may not help, Also, since replacing the board didn't work, I will suggest going right to the manufacturer on this since the board was the only thing that really made sense for both to be out. Otherwise there might be a loose connection somewhere, anyway call them and let me know what they tell you and if they can't help, then you might have to take it in somewhere to have it checked, but the main board is the only thing that really makes sense
Main support number 714-668-0588
Email supporttechsupport@vinc.com
Posted on Mar 24, 2008
L37 vizio lcd
Do you see any burn marks or leaking components on that board? If the TV's power supply thinks it's on then it would make sense that the problem is on the main board. I've seen it here for sale: http://www.vancebaldwin.com/products/?3370-0082-0150 $126 bucks, not bad.
First try to look really close at the screen to try to see if there is faint evidence of a picture, if so then the problem is with the FL inverter that drives the backlight. But if there is no sound then it's not that but the main board. Good luck!
Mar 20, 2008 | Vizio L37 Television
Have replaced power board and main board... still no picture..
you need to check and see if you have 24v from the power supply to the ballast if you do the problem is going to be the ballast ( inverter board ) bad capacitor
Feb 03, 2012 | Vizio L37 Television
I have a Vizio L37. When I turn on the TV it works perfectly after about 3 minutes the screen goes to green (no picture). However I still have the sound.
My first guess would be your t-con board. The t-con board is the one that transfers teh picture from your signal board to your screen. My second guess would be the siganl board is bad.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Vizio L37 Television
No picture power ups blacklights work no menu no
If you see the back light, then you should have 24vdc on the main power supply board which it gets the turn on command from the maun board. If you do have all those voltage, then it does sound like you need the new main board.
Nov 25, 2009 | Vizio L37 Television
Vizio TV (L37) will power up but no picture
The backlight is powered by its own supply (although it may receive input from the main supply) and it sounds like the main supply or one of its outputs has failed disabling the video and sound processing.
Dec 24, 2008 | Vizio L37 Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
Tv will not turn on.
my vixio l37 will not turn on neither with the remote nor the power unit ,need some solutions
Sep 04, 2008 | Vizio L37 Television
Vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Mar 16, 2008 | Vizio L37 Television
Vizio L37 Television Logo
261 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
