Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
When I try to connect the harddriveto the PC it
When I try to connect the hard drive to the PC it does not appear on the my computer function , I am using windows xp
    Sergeant:
    Novelist:
  • 172 Answers
HI awswin. Connect your hard drive. do you hear the "tutin"(hehe) sound when you connect USB devices? If you dont, that means you have a serious problem with your hard drive. Either the case is bad so you just remove the hard drive from the casing and put in on another one (it could be any extrenal case for hard drives.. as long it has the same interface - SATA or IDE). If you do hear the "tutin"sound, go to Start - right click on MY computer and click on "Manage". Then go to "Disk Administration" above "services and applications" and verify if you see your hard drive. Probably you have to initialize the disk or Assign a letter by right clicking on it. But first try removing the hard drive and connect it to another computer WITHOUT the case to make sure it's not the hard drive. I hope this helps and dont forget to rate my answer if it did. Thank you :D
Posted on Apr 28, 2010
  • 702 Answers
Can be quite a few causes. Have a look at this article on troubleshooting external hard disk problems, maybe it has a fix for you.
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My s2 portable is very sensitive, that when i donwloaded data on it, after a while, it will corrupt my data, and when i try this to connect to other pc, it not appear on MY COMPUTER, but when I reconnect...
Hi ajsallin ,
The problem could be resolved in the following ways :-
  1. Loss of data could occur as a result of directly removing your USB external hard drive without actually disabling it from your taskbar's bottom right corner , where you get an icon of devices connected , it's like a plug icon.
  2. You need to right click on the icon, choose the device that you want to remove and then disconnect it , till it says that you can now safely remove your hard drive.
  3. Once you have done this , try connecting your hard drive , to the USB slot of the different PC, than the one from which you copied the data on your hard drive.
  4. If the drive does not show up in my computer , it could be probably because you are using a USB hub or an extension cable to connect the hard disk.
  5. I would recommend you to remove any such cables or USB hubs and try connect the hard drive directly to your USB port via the cable supplied with the hard drive.
Hope this helps.
May 12, 2011 | Samsung S2 - 320GB USB 2.0 Portable -...
I have a WD 1TB Hard Drive. The HD shows up in 'safety remove hardware' but not in my computer. I have tried to assign a 'drive letter' to it in disk manager but disk manager is showing the hard drive to...
Try the following steps:
1. right click on my computer and select manage
2. choose Storage-> disk management.
If you say that the drive appears in the "safely remove hardware" than it should appear here too.
Select the hard drive and select "change drive letter and path". Add a drive letter and your hard drive
should appear in my computer.
Feb 11, 2011 | Western Digital WesternDigital Hard Drive...
Panasonic DMC - F3. Attempting to load photos from camera to PC. Software provided has been installed. Camera has been connected to the PC via provided USB cable. PC does not seem to recognise...
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 15, 2010 | Panasonic Lumix DMC F3 Digital Camera
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
Help me! I cannot detect my LaCie Little Disk on my MacBook
There are a number of things that could have gone wrong here.
1. Perhaps you have a bad (USB) cable, try another...
2. Perhaps it's the MAC that may be rejecting it, try it on another MAC or PC (if you do try it to a PC and the drive is formatted to MAC OS, you will need to search for it in disk management.
Right Click on my computer > select 'manage' > on the left-hand pane, select disk management. The drive may come up as unknown if it does appear there.
If the drive has a FAT or NTFS fomrat, then the drive should come up under my computer, although I still advise check disk management.
If you try it on another MAC, just check disk utilities again.
3. The drive has a controller failure, which could explain why it appears to be on but not functioning correctly (the controller function is to communicate with the CPU, so that it appears in disc utilities / disk management.
If you are effected by the second option, you will need to get in touch with MAC support...
If you are effected by the 3rd option, you will most likely need to have it replaced
Hope that helps and clears it up for you!
Jan 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
USB DRIVE NOT ACESSABlE
youve got a problem with you USB connection in your PC... try to use another USB connection...
Jun 16, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Rocstor external hard drive does not appear in my computer win xp although message it was installed when I connected the usb port
Good morning! first, make sure your external hard drive is properly connected to the USB port, then try to start / restart your computer again, automatically the computer should recognized the attached external HDD. best regards.
May 02, 2009 | Computers & Internet
I can´t see the portable hard drive unit in my pc
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Feb 18, 2009 | Verbatim External, USB 2.0, 750GB...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
173 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
