Question about Dometic Rooftop RV Air Conditioner
Looking for schoolbus roof-top AC installer in Houston, Texas.
I've not been able to locate a company that installs an AC unit on the roof of my 1992 , 14-seat school bus in houston, Texas
Thanks
  • Mike Butler
    Mike Butler May 11, 2010
    Have you tried checking at an RV sales and service place?
  • 81 Answers
You can get lots of roofing companies in Houston TX. Just like CM Construction Remodeling, It is near to your location and helpful for you, get a fast response with reasonable price.
Posted on Apr 17, 2015
5 Suggested Answers
  • 9 Answers
SOURCE: roof top rv air conditioner installation
Waeco manufacture a rooftop A/C with a matching inverter.you will need to ensure that you have enough battery power when staionary but your al;ternator will provide power when mobile you could also use a small generator through a battery charger to keep your batteriesd charged up but this is not neccessary unless you are stopped for a long period of time.these units are fairly easy to install and come with fitting instructions for the A/C and wiring kits for the inverter..hope this helps
Posted on Jan 14, 2009
SOURCE: RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Posted on Mar 18, 2009
SOURCE: seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Posted on Jul 24, 2009
motor1258
  • 6674 Answers
SOURCE: Have a Quick Cool RV roof unit compressor:
Try ( www.dometicusa.com) site and they have dealer locator on there site for wherever you are.
Posted on Jun 24, 2010
What is the biggest roofing company in the US?
2015 Top 100 Roofing Contractors
Rank Company Name Location 1. CentiMark Corporation Canonsburg, PA 2. Tecta America Corporation Rosemont, IL 3. Baker Roofing Company Raleigh, NC 4. North American Roofing Services Inc. Asheville, NC 96 more rows
www.roofingcontractor.com/RC-Top-100-2015 What is the biggest roofing company in the US Google Search
try this link might help.
Dec 15, 2016 | Cars & Trucks
Where to get idea for kitchen renovation!! Is it right too hire contractors?
I think that one of the biggest benefits of hiring a contractor is the stress it saves. I work a lot and don't have a lot of free time so I almost always hire someone for my home repairs and remodels. It just depends on how much of your own time and effort you're willing to invest.
REMODEL
Dec 02, 2013 | All Phase Remodeling Dream Home Remodeling
I'm looking for a company to instal a roof hatch in my loft. Can anyone recommend anyone in the Minneapolis area?
You could try Nystrom; they are based in Minneapolis and seem to have a good selection. check out their link -
http://www.nystrom.com/roof-hatches
Jan 15, 2013 | Building Materials
I purchased a dometic roof top ac unit mdl#641515.301c0, however on the website i cannot find install manual or user manual
What part about installation are you having problems with, and what are you installing it on? Do you have both upper (roof) unit & lower ( at ceiling) ? Is it a ducted system or blowing directly from ceiling assy?
Check this link as well , you may find 6300 series is same install.
http://www.dometic.com/enus/Americas/USA/RV-Products/Manuals-and-Instructions2/
Jun 02, 2012 | Dometic Rooftop RV Air Conditioner
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
May 17, 2010 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
How to remove the complete roof top ac unit , 1980 GMC Tioga RV
Shut off Any AC power (hydro) to it, remove ceiling assy (inside part) and you'll see 4 bolts going up through lower assy, and into base of upper assy (roof unit) . Remove those 4 bolts and any wiring harness connected from lower to upper unit. Lift it off. If your just replacing the upper assy, leave hydro wires hooked up to lower assy , and let it hang, while you clean surface on roof for new install. Re-install 4 bolts and tighten equally until gasket is approx 1/2 thickness it was before tightening. Re-install wiring harness plug in to lower unit etc. If not replacing, but removing entire assy (upper and lower) be sure to Marette and tape hydro wires as well as any 12 volt wires, and tuck away safely. Install a vent on current opening , or whatever you choose.
Sep 28, 2009 | Dometic Rooftop RV Air Conditioner
Seal for roof top ac unit
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
167 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
