Question about Motorola Mobility Motonav TN30 Car GPS Receiver
Good afternoon, I am in Brazil and I have no support for the device motorola tn 30. I tried installing the program on my Motorola phone Miopocket Montonav TN30 and during installation time to copy files the program stopped getting frozen on the screen. After a while Shut off the machine and rebooted and there came the surprise that I was stuck on a blue screen with an "X" in RED in the center of the screen and not get anything. Already reseted, I took the battery cable, formatted my SD and the only thing I can access it via USB cable SD. Have you any idea how to help me, to really solve my problem. In its look. Mario
  • 121 more comments
  • Mario SOuza Apr 28, 2010
    Good evening,
    I did as its orientation and the unit got the stat update, but did everything correctly and got to the end of the process stating that the installation of kernel image files was successful. '
    But when rebooted the machine back to the starting point, blue screen with a red "x".
    I await new oriantação.
    Thanks
  • Mario SOuza Apr 29, 2010
    Good afternoon, I am in BrazilGood afternoon, I am in Brazil and I have no support for the device motorola tn 30. I tried installing the program on my Motorola phone Miopocket Montonav TN30 and during installation time to copy files the program stopped getting frozen on the screen. After a while Shut off the machine and More
    Comments:
    Apr 28, 2010 - Good evening,
    Thanks
    Thanks for your help, hopefully someone else can guide me to solve this problem. If you know some link that can download the software for resettlement would be very grateful.
    Regards
    I've done this procedure and did not work.
    The installation goes right until the end and after rebooting back to the problem cited.
    I think maybe have to reinstall everything from the beginning, the problem will not affect the WinCE too?
    I look forward to feedback, thanks.
    Good afternoon,
    Is there any program that can delete and reinstall the original program that do not have.
    I can only see the SD card and can not synchronize with your PC, use Windows 7.
    Regards.
    Good afternoon,
    Regards.
    Good afternoon,
    A) Miopocket 3.0 Revision 59
    B) did not understand what is shut off? The machine is a motorola MOTONAV TN30.
    Good afternoon,
    Tried but nothing works, still the same problem. Thank you.
    I tried using the ASRDisp.exe and does not find my device with Mesnager: "Can not detect ActiveSync connection." and when leaving the message "CERHost: Error 10004 from accept".
    I can not access my device and some hours activesync does not detect the device. I await further guidance.
    Thank you.
  • Mario SOuza Apr 30, 2010
    I'm running out of hope of solving my problem, because what has made me not working.
    The only thing I can see the gps using the usb cable is the sd card, nothing else. And not putting the program back in sd Miopocket and renaming the files are not being read, the one that is recognized is the upgrade from motorola as quoted anteiormente.
    In anticipation of a better solution, thank you.
    Hello everybody,
    Good afternoon,
    I think that's what happened with my set as hung up after a while without continuing the installation and the screen had frozen and could have damaged any internal file.
    But not spotted on the website of motorola any program to do the original installation, you could pass me some link to access and download and then put in my sd because it is the only thing I can access the GPS via USB.
    Thanks and I await your return.
    Please
    Some of you know how do I fix my MOTONAV TN30 is probably with the internal files corrupted by a bad software installation Miopocket 3.0 R59.
    After attempting to install the device only shows a blue screen with a big red "X" in the middle and I can only access the device via USB only seeing my SD card and nothing else.
    I tried to upgrade downloaded from Motorola and has been recognized, started the update procedure, but after you boot back to the same screen.
    Sure of a solution and support I thank you.
    Regards
    Good evening,
    Does anyone have the name of the program to reinstall the ROM MOTONAV TN30 or link to download.
    According to information I'm having, I have lost the ROM of my gps and the only recovery you can work again. I think during the installation of 3.0 Miopocket R59 when he stopped and froze and I had to reset the unit that broke internal WinCE some file or something and there was only my device with the blue screen and the red "X" in the middle.
    Thanks again anyone who can help me
    Good evening,
    From what I see I have to retrieve the programs installed in the ROM of my gps, because I think during the installation files were corrupt equate the installation stopped and restarted the machine.
    Does anyone know where I can find programs to retrieve the ROM motonav TN30 and how.
    Thank you.
    Thank you.
  • Mario SOuza May 01, 2010
    Thanks for the manual but have got, what I need is to restore the programs in the rom of the device because it damaged, I believe the WinCE corrupted by this problem at the facility mentioned above.
    Regards.
    Ao menos você pode citar qual programa procuro, pois estou sem direção alguma.
    Obrigado.
    Thank you for the tip but my device is not a phone but a GPS Motorola MOTONAV TN30.
    Thank you.
    I've tried and failed. But back then upgrades on the same screen problem.
    Thanks
    I appreciate your interest, but I await someone else who can help me solve this.
    Regards.
    Thanks for the support I will try tech support.
    Thanks but I already did this link and download, but without success as mentioned earlier.
    I have this manual and has no information to solve my problem.
    Thank you.
    Thank you.
    If you have another link to thank you for this program is not downloading but an infinite loop.
    Thanks for your help, but I need to solve an internal problem of software on the device and not tracking satellites. I'm with broken files at system startup. Regards
    I will access it from another browser. thanks
  • Mario SOuza May 02, 2010
    Dear FixYa,
    Can not get no access to my unit, I think the problem must be with the ROM that was corrupted in WinCE installation of the Miopocket 3.0 R59.
    Thank you did not work.
    Thank you for your attention, it really sounds strange to my problem, but already requested my removal from the site and reimbursement in accordance with the terms and try to solve technical assistance using the motorola. For now I have to thank all who were willing to help me, but without success. Regards.
  • Mario SOuza May 03, 2010
    I who thank you, have a great week.
    Thanks for the tip, I'll be trying to get the initial installation on the site.
    Thanks
    Thanks
    OK, following the serial so you can provide the link to download the firmware. I am awaiting your return.
    SN: 8322520808945
    I sent email to support as directed, I am awaiting feedback. Thank you.
    Thank you for your guidance.
  • Mario SOuza May 04, 2010
    I've already downloaded this file and the installation was ok but not after restarting the machine back to the same screen.
    The year and month are: October 2008.
    Thanks
    Thanks, but I've downloaded this file and the installation was perfect but after rebooting the machine back to the same problem.
    Have reinstalled the upgrade motorola site and has not worked well. Thank you.
    Thanks but I already have this manual and did as directed but without success.
    Does not work, thanks
  • Mario SOuza May 05, 2010
    Good evening,
    Among the options that I questioned all are working:
    1) Battery 100% loaded;
    2) Corrupted files <== This is where the problem is only that in the ROM gps;
    3) Flash memory, I believe that as this problem has not received the upgrade from motorola and up until the end, the machine restarts, the splash screen displays the Destinator 8 with the updated logo, but the arrow does not appear to loading and after some seconds will for the blue screen problem.
    I appreciate and look forward further information.
    Good evening,
    Thanks for the tips, but can not access the GPS ROM with USB because it is being recognized, only the SD card.
    Thanks I will evaluate the feasibility and compatibility of the program with my GPS device.
    Thanks, I'll make contact with an assist Motorola to try to reinstall this firmware.
  • Mario SOuza May 06, 2010
    I tried the options you gave me but all were unsuccessful.
    Actually found malware in files downloaded and all that Miopocket eliminated. Probably was infecting my machine also, how do I check because I still have no access to the GPS firmware. For the moment, thank you.
    I downloaded media center 6.1 for windows 7 to install but it is not recognizing drivers for MOTONAV TN30 stating that the device is disconnected and not identified.
    I did as requested and ran the program has detected that a unit with the following information: "General Flash Disk Drive 2.05 (0MB) (F: \)" and when I try to format the following message appears: "There is the media in the specified device .
    And therefore do not know what to do. Can you give me guidance on how to proceed to format the ROM?
    Thank you.
    Thank you.
  • Mario SOuza May 07, 2010
    Thanks
    Thanks, but I've downloaded the firmware and installed it normally, but restart the machine and the problem continues.
    Sorry but this attempt has been made countless times without success. Thanks
    Thank you, I will check the feasibility to send to repair.
  • Mario SOuza May 09, 2010
    Thanks
    I will evaluate and see the possibilities this site. Thanks
    Thanks but not worked.
    This has been done without success. Thanks
    when the SD card is formatted and empty.
    Thanks
  • Mario SOuza May 10, 2010
    Thanks for the info, I will be contacting the manufacturer.
    I'm also thinking it might be a hardware problem, because everything I try does not work. I will try to contact the manufacturer.
    I'm trying your suggestion but I can not run the autorun.exe file from my file manager and also I am not able to pair the PC with GPS.
    I still unsolved, because the Motorola does not want to support because they bought the unit here in Brazil and just got the invoice America.
    It would be OK, but the Motorola does not want to support because the U.S. bought unit and the invoice is American. So I am trying to support through you. Thank you.
    Thanks
    I tried I could not find it, if you know where to find the link thanks.
  • Mario SOuza May 11, 2010
    Thanks
    Thanks
    Thanks
    Thanks
  • Mario SOuza May 12, 2010
    ok
    Thanks
    Ok.
    Thanks
    Thanks
  • Mario SOuza May 13, 2010
    Ok
    Ok.
    Good afternoon, but made no qualification as to his person, just thankful to have everyone like you who have tried to help me and unfortunately we're not succeeding. But it is clear that not qualify in any way.
    Thank you for your understanding.
    This is my choice for the moment, because I tried everything and nothing worked. I will be sending to the assistance of motorola. Thank you.
    Thanks, I'll try.
  • Mario SOuza May 15, 2010
    Thanks but I tried and got no help from Motorola Brazil because the device was not bought here and they do not support, even if it is a product of the same brand.
    I've done the update without any success. Thank you.
    Thanks
    Thanks
  • Mario SOuza May 18, 2010
    Thank you for the tips, Motorola really is weak for lack of commitment.
    Thanks, I´m try.
    Ok.
    Thank you for your guidance, I will accept this and send the unit for assistance there in the USA because here in Brazil they do not provide the fix since it bought the unit here but there.
  • Mario SOuza May 19, 2010
    Thanks
    Does anyone know or know where I can find an archive of original Cabinet Software MOTONAV TN30 that can be placed on a SD and reinstall to solve my problem.
    I think it will resolve, once the device connects stopping after you start the Destinator 8 getting frozen on the blue screen with a red "X".
    I greatly appreciate the help.
    Already performed this procedure and not getting hit once just an upgrade and not the initial installation of the device. What really need is the full program to start using a "Plant SD. Thanks
    Thanks
  • Mario SOuza May 21, 2010
    Good evening,
    I got a machine like mine borrowed and used the program to start the WindowsCE startwin.exe renaming AutoRun.exe getting to pair the GPS with the PC, but I'm trying to copy all files to generate a backup and then try to save the SD reinstall the device with my problem.
    What happens is that I can not copy all files and also I have no idea how. Could you help me or guide in any way?
    Thank you for your dedication.
    PS: Please excuse my English, but I'm using Google translator.
    Thanks for the info, let more clear that I have no intention of piracy or something similar, just solved my problem with the GPS.
    I appreciate your concern and dedication.
    Thanks
    Sorry, the page you requested was not found.
    Please check the URL for spelling errors and try again, or go to the FixYa Home Page
    Looking for a product? Type the product name and model number in the search box below.
    Thank you, I am closing my case, but as I proceed to not take the time for you anymore?
    I´m try locate software. Thanks
    Thanks
    Thanks
    Thanks
  • Mario SOuza May 23, 2010
    Thanks
    Thanks
    Thank you.
    Thanks
    It did not work, I tried before
    Really the only option that would be sent to Motorola, but bought outside Brazil as they refuse to provide technical assistance. Even so I appreciate your attention.
  • Mario SOuza May 25, 2010
    Thanks
    Thanks
  • Mario SOuza May 26, 2010
    Thanks. Ok.
    Thanks.
  • Mario SOuza Jun 01, 2010
    Thanks
    I congratulate and thank all the effort dedicated to my problem, that although we did not find the solution was the most ardent and dedicated.
    Again thank you.
  • 5,807 Answers
Hi
mario_souza,
First of all , I want to thank you in advance for choosing Fixya
for assistance.
I would like to clarify some details before i present my solution
to you.
a ) What program have you installed ?
b ) What shut-off ? what machine?
and here what i got from the manual
Good afternoon,
Hope to have a response from you soon , as i look for a possible
solution on your problem.
regards,
palaboy
Posted on Apr 29, 2010
  • 40 more comments
  • Rommel Cana
    Rommel Cana Apr 29, 2010
    These one is for the TN30:
    To reset the TN30, press the Power button for 8 seconds, then press Power
    button again to turn on. You can use a pin to reset button when the unit is on.
  • Rommel Cana
    from what you mentioned " After a while Shut off the machine ...... "
  • Rommel Cana
    here is additional info in case these is your problem:
    My touchscreen has stopped working!
    This can happen on certain devices when you enable Transcriber or JOTKBD. On most devices, a hard reset or shutdown of your device will undo everything. Try holding down your power button for up to 10 seconds, waiting a few seconds, then holding it down again. If MioPocket is still installed (or that doesn't work), connect your device to USB. If it successfully connects and you last left it set to ActiveSync mode (MioPocket's default), then, from a Windows computer, run MioAutoRun\Programs\Win32\ASRDisp.exe (for the best performance, run a local copy). Are you able to use the device that way? If so, run one of MioPocket's file managers and skip the next paragraph before continuing reading.
    If, for whatever reason, you are not able to use ASRDisp.exe to remote control your device, create a folder named 2577 on an SD card, copy the contents of MioAutoRun\Programs\FileManCE2 (from the MioPocket zip) to that folder, then rename FileManCE.exe to autorun.exe. Insert the card into your device and the file manager that you just copied to the folder should run.
    From the file manager (that you ran through ASRDisp.exe or that autoran for you from the card), navigate to MioAutoRun\Scripts\UninstallKeyboardDriver.mscr and run it. Next, run MioAutoRun\Programs\Reset.exe or Restart.exe. If, after reset, MioPocket is still installed and the touchscreen still doesn't work, use the file manager to run MioAutoRun\Registry\Exclude\OriginalKeyboardDriver.reg and MioAutoRun\Registry\Exclude\TouchscreenBackup.reg (one of which contains your old keyboard/touchscreen driver settings). Repeat the reset. If even that doesn't work (or the files don't exist or you can't choose Yes to the prompt), run MioAutoRun\Programs\TroNik\TouchScreenFix.exe and reset.
    If none of the above work and you have file access to your MioPocket installation (either through USB or, if installed to SD card, by removing the card and putting it in a card reader), here are some more things to try:
    * Find the executable that you originally launched MioPocket from (either MioAutoRun.exe or Miomap.exe before you renamed them) and copy MioAutoRun\Programs\TroNik\TouchScreenFix.exe in its place, renaming it to the appropriate name.
    * Open up MioAutoRun\MioPocket.ini, find "InstallTransciberDriver" and set it to 0.
    * Open up MioAutoRun\Scripts\StartupPrograms.mscr, scroll down to the bottom and move the "Call("TestTouchScreen")" line to below the "EndIf" line.
    * If you can connect in ActiveSync mode (but, obviously, can't use the aforementioned ASRDisp.exe to control your device), then, from a Windows computer, run Mobile Registry Editor from the MioAutoRun\Programs\Win32 folder. If that connects, then manually edit the registry back to the settings that you find in the OriginalKeyboardDriver.reg file mentioned above.
    After each of the suggestions immediately above, try to hard reset your device and re-install MioPocket. Admittedly, this may be easier said than done without use of the touchscreen. Just keep in mind that, often, you can reset by holding the power button down/off for up to 10 seconds and, with SD installations, MioPocket can often be re-installed by inserting the SD card or tapping the power button off, then on again. If you have done an SDfree installation, try putting MioPocket on an SD card and performing an SD installation via the instructions in this Readme or elsewhere online.
    excerpts from the readme file
  • Rommel Cana
    here is the link for your guides :
    http://www.gpspassion.com/upload2/MioPoc... Readme.html#5.12
    hope these helps
  • Rommel Cana
    Rommel Cana May 01, 2010
    you can try these linkhttp://www.mediafire.com/?vxmziagqzmz
  • Rommel Cana
    Rommel Cana May 02, 2010
    after downloading the said installer, it is a zip file , you may try to read again all the readme files
    on its folder inside the installer .( only after extracting it to a folder of your choice ).
    There are a lot of them to read, and I am reading some of it , just right now.
  • Rommel Cana
    I forgot to tell you, after downloading the installer ( zip file about 88.9MB ) , make a folder of your
    choice ( root directory perhaps is better , like drive C not inside the Program Files ), and copy
    or cut the said folder to it. Once copied , extract all of them inside the folder that you have
    created . Although like the installer said , you may need not to copy all of them to your card.
  • Rommel Cana
    Rommel Cana May 03, 2010
    there might still be other alternatives like using a USB to serial port Adapter.
  • Rommel Cana
    Rommel Cana May 06, 2010
    i would also suggest having a software for malware like
    http://www.malwarebytes.org/mbam.php
    and scan on your computer.
  • Rommel Cana
    you may need to have these Active Sync from Microsoft:
    http://www.microsoft.com/windowsmobile/e...
    choose the one that is right for your operating system.
  • Rommel Cana
    Rommel Cana May 07, 2010
    on SD card :
    You may need a separate card reader, if formatting the SD card as FAT 32
    ( with an allocation unit size of 64KB ) wont do
  • Rommel Cana
    you may need to download these also on your computer:
    http://www.microsoft.com/downloads/detai...
  • Rommel Cana
    Rommel Cana May 08, 2010
    i have found also a web site where you can try re-installing the firmware:
    http://www.goodslowprice.com/en/unlock.h...
    only with a fee.
    But , check first the files that are installed and copied to the SD card as stated on the readme
    files above.
  • Rommel Cana
    Rommel Cana May 09, 2010
    try to post a snapshot of what s inside your SD card
    or the details what files have you copied on the card.
  • Rommel Cana
    Rommel Cana May 10, 2010
    the SD card should have:
    ( from the solution I posted April 29 )
    a ) create a folder named 2577 on an SD card
    b ) copy the contents of MioAutoRun\Programs\FileManCE2 (from the MioPocket
    to run
    Mio AutoRun\Registry\Exclude\Original Keyboard Driver.reg and
    settings)
    If you can connect in Active Sync mode (but, obviously, can't use the
    Mio AutoRun\Programs\Win32
    settings that you find in the Original Keyboard Driver.reg file mentioned
    above.
    After each of the
    you
    again. If
    you have done an SD free installation, try putting MioPocket on an SD
    card and performing
  • Rommel Cana
    Rommel Cana May 11, 2010
    or the
  • Rommel Cana
    what files are installed or copied on the SD card?
  • Rommel Cana
    Without any files on the SD card , there would be nothing to read ( boot ) for your Motorola unit.
    These unit needs something to read ( instructions ) to start up again.
  • Rommel Cana
    Rommel Cana May 12, 2010
    thanks also
  • Rommel Cana
    Rommel Cana May 13, 2010
    thanks for choosing Fixya for assistance!
  • Rommel Cana
    Rommel Cana May 18, 2010
    here is another link:
    http://support.delorme.com/questions.php...
    try to follow instructions on installations
  • Rommel Cana
    here is a snapshot of the program:
    • Auto-Start - Automatically
      starts the GPS when it is plugged in.
    • Start - Starts the GPS.
    • Stop - Stops the GPS.
    • Exit - Exits the utility.
  • Rommel Cana
    include these link also:
    Windows Mobile
    Device Center 6.1
  • Rommel Cana
    Rommel Cana May 20, 2010
    install OpenGTS
    The document "OpenGTS_Config.pdf",
    included in the downloaded zip file package,
    contains step by
    step information for installing OpenGTS.
  • Rommel Cana
    Good evening,
  • Rommel Cana
    Rommel Cana May 22, 2010
    On your computer, you must be an " administrator " or have privilege to access inside the
    computer or the one that owns your computer that you are using.
    You need to go to " Administrative Tools " inside Control Panel.
    From " Administrative tools " go to " Computer Management ".
    Under " Storage " select " Disk Management ".
    Once selected you may be able to see your SD card.
    " Right click " on it and open.
    Do what you need to do, and post again
  • Rommel Cana
    snapshot of " Disk Management "
  • Rommel Cana
    Of course the unit must be connected via USB, try also on your other GPS if you can and post.
  • Rommel Cana
    You can also use " Im Translator " , if you are using Mozilla Firefox.
    Thanks for all your good intentions, but managed to synchronize the device time to manage but does not show the files to backup. If you have any alternative, thank you otherwise just post for me to accept your solution and then score on their behalf, because who else has helped me. Regards.
  • Rommel Cana
    Rommel Cana May 23, 2010
    you have synchronize the time?
    that is a good sign.
    It means you can partially communicate with the device.
    Here is what I like you to do:
    Since you have another GPS try to rebuilt or make the program working , in your computer.
    You can verify , the Program ( program that is created by the software ) by applying it to the other
    GPS to know if it working ( running ).
    If it do, then try it your own GPS and post what you find.
    Verify too, if that program can access the SD card of the other GPS.( not your GPS )
    if it can , copy all the contents to a separate folder on your computer ( only if it can be copied )
    ( maps possible , I'm not sure about other files ).
    Keep in mind , your goal is to make the software run ( program ). If it is good and running , maybe
    we have a chance. Check the program on other GPS , to see if it is good and running.
    post what you can access on the other GPS.
    Yes I could access the device you're with me, I could also copy the entire folder that contains the Destinator (My Flash Disk \ MobileNavigator), pore the folder with the windows CE (\ Windows) can not copy some files because speech that are not in use may be copied, I think this is where I'm having problems with my gps.
  • Rommel Cana
    Rommel Cana May 24, 2010
    here is a link, try to download these MOTOEXTRAS TOOLBOX
    https://motonav.naviextras.com/shop/port...
  • Rommel Cana
  • Rommel Cana
    after downloading, install and test it on the working GPS.
  • Rommel Cana
  • Mario SOuza May 24, 2010
    I tried but I could not run, I do not know to use the program GPS3 Codeplex. But through windows explorer I can see all files of the GPS just can not do the backup. Thank you.
  • Rommel Cana
    Rommel Cana May 25, 2010
    Dependencies
    This project depends on other projects available here at CodePlex:
    GeoFramework
    2.0
    http://geoframework.codeplex.com/
  • Rommel Cana
    Seeing the files is also a good sign .
    please read carefully the following articles:
    http://motorola-global-portal.custhelp.c...
    here are some of it,
    You can transfer files from a computer to your memory card with a
    cable connection or by using a card reader.
    Cable connection:
    1. Make sure the phone is not connected to the computer
    2. Press the Center Select key
    3. Scroll to and select Settings, Connection, and then USB Settings (If
      this option is not available see Memory Card Reader below)
    4. Highlight Default and press Change
    5. Scroll to and select USB Drive and press Select
    6. Press the Clear key to return to the home screen
    7. Connect the cable to your phone and to your computer
    8. Open your "My Computer" window where your phone's memory card
      displays as a "Removable Disk" icon
    9. Click on the "Removable Disk" icon to access the memory card.
    10. Drag and drop the desired files into the memory card window to copy
      them onto the memory card
      Note: You may see "Mobile" and "Motorola" folders in
      the memory card window. Do not delete these folders because they are
      used by the phone.
    11. When finished, disconnect your phone by clicking "Safely Remove
      Hardware" icon in the system tray on your computer, then selecting
      "Safely Remove USB Mass Storage Device"
    12. Disconnect the cable from your phone and computer.
    Thanks for any help, but unfortunately I see no other solution than to send the technical assistance of Motorola through my cousin who lives in Canada, which made today and will wait for the return.
    I leave here my sincere thanks and how you was what was more dedicated to solve my problem do you qualify.
    Regards.
  • Rommel Cana
    Rommel Cana Jun 01, 2010
    Thanks once again for choosing Fixya for assistance .
    I hope your unit will be back , OK soon!
    Guru:
  • 302 Answers
Try updating your model. Read the following carefully.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/MOTONAV%20TN20/US-EN/_Documents/Static%20Files/MOTONAV%20Web%20Download%20Install%20Instructions%20v8.pdf
If this doesnot work then you must contact Motorola service center. The problem in your device is surely a faulty firmware it can absolutely be fixed by the Motorola people if they want to.
Posted on Jun 01, 2010
  • 2,973 Answers
Mario,
You must immediately take the phone to the service center and get the firmware reinstalled. Or if Motorola has the facility to install it at home over the internet, then you must do it yourself. I am sure there must be some dealer who is capable of doing it for you.
Posted on May 05, 2010
    President:
  • 1,070 Answers
Hello ,
I think Following Guide Surely will Help you to Software Update.... Click here
Do you need Use help Guide for you Device ...?(If need i will Upload here)
Thanks for Contacting FixYa....Keep Using...
Posted on May 04, 2010
  • shafi
    shafi May 04, 2010
    As you said the Problem Found after Installing Program.That program might caused this error/the file you tried corrupted.Then you did well Software Up-gradation.Most times Software Problem will Clear by Software Update..
    You have to Do Following
    • Press the Power Button 8 Seconds
    • Hold Power button to turn on
    Then you can See a RESET button on Side of your Device Press it for 3 to 8 Seconds
    (Using a small Pin)
    OR Power off Phone and Don't make any attempt for Few hours. try the Update Process only after few hours.(Sometimes Continuous Software may Create Clash.So this is to refresh)
    ....Hope you can do well ...Keep Using...
    Note:to make any process..Ensure Device is Fully Charged....
  • 10,865 Answers
Hello Mario. Even though there is no support within Brazil you still have support. Go to this link to access it. http://www.motorola.com/Consumers/US-EN/Contact-Us/Corporate
Joe
Posted on May 03, 2010
  • 4,924 Answers
This means that the update wasn't successful and the device has no viable operation system (firmware ) so ..what you have to do ..is go to the manufacturer site and download again and try to reinstall it ..cause if the reset wasn't helpful this means that there is no other way..at least its connecting and this is a good thing ..means that the drivers still pair with the device ..
  • Catalin Turcu
    Catalin Turcu May 07, 2010
    It seams that it detected the internal flash where the firmware should be installed..cause any other flash memory into this device should be larger...so ...this means that you installed the driver properly and now all you need is the firmware ...just download it from the official manufacturer site ..and cause the communication between devices is already done...just run the firmware soft and follow instructions..
  • 2,335 Answers
I can help you with your Motorola Motonav TN30.
It sounds like you need to reflash the firmware / reinstall the system software. This can be done downloading new system software and running it on your computer to reflash your GPS.
In order to download the system software from Motorola a serial number and possibly a purchase date is required.
Good afternoon,
I am happy to help: post the information required to me & I will provide the system software.
I hope that helps.
_____________________________________________
Motorola Motonav TN30 Manual Download
Posted on May 02, 2010
  • Paul Sager
    Paul Sager May 02, 2010
    Here at Fixya, we do not get to see what other people have written until we post our solution. Now that I have reviewed your file here, I can see that you have had trouble getting proper help.
    I can see that we are on the same page as to how to repair your Motonav TN30.
    What you call 'ROM', I call firmware & I specialize in repairing firmware here at Fixya for cameras, cell phone, MP3's and of course GPS. I specialize in Garmin GPS, but it is essentially the same process for all devices.
    The only reason I haven't just sent you a link to download your firmware to fix your Motonav is that Motorola tightly controls the download of this software, as I documented above in my first post. If you can provide a serial number, we can move this forward.
  • Paul Sager
    Paul Sager May 04, 2010
    Someone else has apparently attempted to download the Motorola Motonav TN30 System Software replacement program using the serial number you posted, and messed it up by entering a purchase date beyond the extent of the units warranty. This serial number is now locked out from accessing the system software download.
    This is the message I received after entering the serial number you provided:
    Here is the message big enough to read.
    If you would like to follow up with Motorola's Customer Service Representative, this is the link in blue.
    You may be able to source the system software file you need by corresponding with Motorola, although I wouldn't necessarily offer up the fact that you are in Brazil to them. Once you have the file you require you may find these Fixya Tips handy when it comes time to install your replacement system software:
    Motonav TN30 Firmware Fix
    Motonav TN30 Upgrade Manual
    I hope that helps.
    Genius:
  • 1,354 Answers
Hi
go to folowing site you will find user manual of your product just folow the manual you will find your soulution
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/TN20_TN30_UG_68000201366Aa.pdf
if not then you can contact me
Posted on May 01, 2010
  • To get started, you need to turn on your MOTONAV and configure initial device settings:
    1. Press and hold Power button to turn on the device until the display becomes active.
      After a few moments, a configuration wizard appears to provide step-by-step setup instructions.
    2. Set your language preference and tap OK.
    3. Review Warning message and tap OK.
    4. Review End User License Agreement (EULA), then tap I Agree checkbox and OK.
    5. Set your time zone settings and tap OK.
    6. Set your preferred measurement units and tap OK.
    7. Verify that the device displays your current location on the map view
      screen like shown below.
      If you see Finding Your GPS Location at bottom of the screen, the MOTONAV is searching for GPS satellites. Move device to an open location with a clear view of the sky and wait a few minutes to obtain
      satellite GPS signal. When obtained, your current location appears on the map view screen.
    8. Initial configuration of your MOTONAV is now complete
  • if your not able to solve your problem then you have tak it to the workshope and if it's less then one year thne it has worranty they will do it free of cost
    President:
  • 1,118 Answers
If you haven't already done so, go to this page, fill in the required data there, and try to move on.
Hope you are able to sort your problems out.
Cheers! Carlos
  • 2 more comments
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR May 01, 2010
    Oops, have forgotten to attach the link. It's here!
  • CARLOS R SOUZA JR
    Have you already installed these software parts on your computer? It takes a while to install, but, at the end, it should recognize your device when you connect it through USB. I'm not sure if it will work in your case, though, because your device seems to be frozen...
  • CARLOS R SOUZA JR
    Try to access the site through Google Chrome or Mozilla Firefox, because MSIE is issuing an error code here.
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR May 02, 2010
    Have you already tried to remove the SD card from its slot, press and hold the power button for 8 seconds, in order to turn your device off, and, then, briefly press the power button again to turn it on? (i.e. reset without the SD card).
  • 12,061 Answers
Www.motorola.com/.../Product%20Manuals/.../TN20_TN30_UG_68000201366Aa.pdf -
www.motorola.com/.../MOTONAV%20Web%20Download%20Install%20Instructions%20... -
www.motorola.com/Hellomoto/Master%20Lists/.../US.../TN30_QSG.pdf
OK, please find your manuals above. use these to troubleshoot. I think what you need to do is a factory reset, you need to connect up to a PC, and download any updates and software, from the Motorola website.
Get Motorola Phone tools, and install on your PC, Hook up to your phone and fix your unit.
https://supportforums.motorola.com/thread/25641
A support forum. above.
http://www.motorola.com/support/v/index.jsp?vgnextoid=25aae66506e9d110VgnVCM1000008406b00aRCRD
Above motorolla
  • 713 Answers
Hi,the ROM is crashed as a result of a system error which occured during the installation of the program,however the ROM has to be flashed to restore your device back in a perfect working condition,however you have to download the software to enable the flashing process,the software can be downloaded at www.rapidshare.com,you can also get a detailed description on how to flash the firmware of you device,but to be sincere with you,the process is a really cumbersome and difficult task,so be careful,so you don't ruin your device's ROM completely.
Thanks and take care
Posted on Apr 30, 2010
  • Oyelade Gbenga May 02, 2010
    Hi,from the initial stage when you posted this question when i told you the ROM of this device was the problem,that it was corrupted and had to be flashed,it sounded awkward but as an expert,you advice customers but you don't force them to accept your solution,but to save you from unnecessary stress,the best solution is to get the entire ROM of your device flashed completely,to restore your device back to a perfect working condition.
    Thanks and good luck
    the choice is all yours
    Genius:
  • 1,341 Answers
Since the device came to a stop during installation, there is a big possibility that the software has been corrupted on it. The best way to solve this problem is to connect the device via usb to a pc, then back up all the files that you can see. Once done, go to the manufacturer's website or do some google search for this particular software.When done, upload the software via usb onto the device and start the device. This should solve your problem. Good luck with it.
  • heeman mohun May 01, 2010
    I would suggest you look for it using bittorent.It is the best source if you cannot download it from the manufacturer's website.
  • 17,970 Answers
Requiring a hard reboot with the bottom-mounted pinhole reset button. Freshly reset, the Motonav TN30 was again usable. Try it and tell us news.
  • ZJ Limited
    ZJ Limited Apr 29, 2010
    Search in the official site about TN30: mediacenter.motorola.com
    Its possible that you can read this link with comments about your NAV model: instalar-mapa-motorola-motonav-tn30-tn20 (in spanihs, but is very easy)
    Good luck.
    NOTE:
    shut off = turn off
  • ZJ Limited
    Had to do a remote support call today for someone having trouble with a
    MDA Compact II , which is a PocketPC phone.
    After unsuccessfully trying to walk the user through the simple steps
    required to change their email I did a search and came up with a
    Microsoft tool for remote controlling the PocketPC via the PC (which in
    turn I could see via VNC). This wasn't available as a free application
    when I last used an application to remote control a PocketPC.
    After installing this on the PC (and thereby the PocketPC once the owner
    plugged it in) I was able to resolve the issue quickly. Funny really as
    he was about 10 minutes walk down the road!
    You can get the Remote Display Control
    for Pocket PC from the Microsoft website
    If you receive just a blank white screen on the PC and when you close
    the screen you get a message box titled "CERHost", stating "Error 10004
    from accept" then do the following:
    1. Ensure that the device is connected the the desktop using ActiveSync
    3.1 or above.
    2. Launch the desktop host by clicking on Start > Programs
    > Remote Display Control > Remote
    Display Control Host.
    3. On the Pocket PC, tap on Start > Programs
    > cerdisp.
    4. Then tap OK > Connect.
    5. Leave the hostname as "PPP_PEER" and tap "OK"
    It should then connect.
    Just a quick note on my particular configuration in hope that it may
    help someone else out:
    1. CK31ex - Intermec Handheld computer w/barcode scanner
    2. Active Sync 4.5
    3. Windows CE 4.01.00.0872 Premium
    4. Intermec Smart Systems Consol 3.50.04.1120
    Most recent versions of ActiveSync and Smart Systems Console as of
    this writing (12/08/2009). Intermec can't help you and most of the posts
    out there are very shallow and vague. If anyone else is messing with
    Intermec equipment let me warn you ahead of time they list this as an
    unsupported feature and don't know much about it.
    Good luck.
    President:
  • 1,469 Answers
That typically happens as a result of an application update that either downloaded an incorrect version of the application for the device, or the application update didn't complete before the device was removed, or the application it downloaded was somehow corrupt.
Try deleting any application updates that were downloaded into HOME, then delete the application from the device, then download the new application update for your device, and install it to the device. Give it a good wait after it says it has finished installing the application update and then be sure to use the software eject button within HOME before disconnecting the drive.
Otherwise, you probably have a call to TT support in your future where they will likely have you download a utility to clear the flash on the drive and reinstall the application on the device after that.
Good luck.
  • 781 Answers
It may be a shot in the dark but it may work if you have already formatted your sd card.
try to do a software update as explained here
good luck!
Posted on Apr 28, 2010
  • 2 more comments
  • Francisco Cortes
    Francisco Cortes Apr 29, 2010
    I was hoping you would get default files on your card expecting that would make it work again. if you didn't you need to get someone to provide you with those default files and folders, or try to replace the card from motorola, or give them a call and explain the situation as they may be able to provide further suggestions
    sorry I wasn't much help!
    good luck!
  • Francisco Cortes
    Francisco Cortes Apr 30, 2010
    how do you know if that you motorola phone has WINCE?
    have you tried resetting your system as follow
    • Press the Power button and keep pressing for 8 seconds,
    • then Press Power button again to turn on.
    what happen after you do that?
  • Francisco Cortes
    questions:
    did tried to install miopocket to the flash memory or the SD?
    have you tried to run again the miopocket installation targeting your sd?
    what installation procedure did you follow? as I can't find your unit being supported.
  • Francisco Cortes
    Francisco Cortes May 01, 2010
    mario
    the link to install the factory or original system files is non existant, only motorola would be able to do such thing (if there's anyone who can). I would suggest to keep trying to reinstall miopocket on your sd which is the only one you can access with the assistan of the people in the forums where you download miopocket in the first place, instructions of how to install to the sd were provided in readme file that I posted on my previous comment or can also be accessed through the installation files of miopocket.
    you need to realize that miopocket and its installation in a device that is not supported by it could cause the unit to become a brick and this may be the current case.
  • 506 Answers
You will need the reload the phone OS. You can use your laptop and download the OS from Motorola Site to your laptop and reload the OS on your Phone. You can also take your phone to local phone repair and the will reload the OS for you.
Posted on May 26, 2010
  • 6,831 Answers
Hello
Unfortunately, it sounds to me like a firmware malfunction. I know this is not what you want to hear at the moment, but, the only way to fix this problem, is to send the device in to the manufacturer.
This is why the manufacturers and selling outlets always provide customers with free "in store" updates, to eliminate customers updating the devices at home, resulting in corrupt firmware.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
  • 942 Answers
Well, if you have done the basic troubleshooting for this and you have done the power battery reset for your micropocket, I will try to find on the web if we have the support repair in Brazil...
click this link here: This website is translated in Spanish, try to find the tech support holine for Brazil so that you can repair your Miopocket..
Posted on May 24, 2010
    President:
  • 524 Answers
Hello Mario Souza,
I know that you already reset the device but try this one more time.
Press the power button for 8 Seconds.
Then press power button again to turn it on.
You can also use pin to press the reset button when the TN30 is on.
Add a comment if you get resolution and let me know if you have still have the same problem.
THanks.
Posted on May 23, 2010
  • 242 Answers
I am afraid to say but is it possible for you to buy a new devise?
I believe that is the only solution for this problem.
Thanks
Jimmy
Posted on May 21, 2010
  • 4,737 Answers
From your statement, it is clear that your there's application incompatibility. The only solution for this is to revert back the settings to previous state and it's not possible without flashing software. What you first need to do is format the phone memory using a flashing software (which you need to go to the repairing shop). Reset it to Factory Default. Please note that, everytime you install an application to your phone whether you install it in your phone memory or memory card, the basic files of the application will always go to root drive (phone memory). Please visit a popular mobile repairing shop and get the phone format, if this can't solve, your last chance will be to flash it. Other mobile phone such as nokia would display "contact service". Anyway no trick to be implemented without the Flashing Software. Good luck
Posted on May 20, 2010
  • 1 more comment
  • Lebanon Raingam
    Lebanon Raingam May 21, 2010
    Good luck Mario, I hope you've improved your english through this :-). You've written a lot. Anyway, it's good that you've made it at last. Please let me know the result.
  • Lebanon Raingam
    Please discontinue your posting for premium assistance, it is still active.
  • Lebanon Raingam
    Lebanon Raingam May 23, 2010
    Please flash it, there's no other solution to get it fixed. I really want to help you, but I can't give more solutions since this is not possible without the Mobile Flashing Software. I hope you understand what I mean. If you don't flash it, you'll never be able to use it. Once again Good luck.
    Guru:
  • 528 Answers
Hi Mario, this could be a software issue in your Montonav TN30. Usually when you installed software in this gadget, it will work flawlessly. What you experienced there is the program will stopped from insatlling and the screen will freeze. This means that the unit Operating system is not accepting the software that you are trying to install. You may try to reset the gadget as basic troubleshooting. Inorder to do this you will be needing a pin to push the hole underneath the gadget for 8 secs then press the power button again to turn on. Do this when unit is turned on.
Best of luck.
Posted on May 19, 2010
    Thank you this has been done without any success, which seems to me that the problem is the software installed in ROM (firmware) who is corrupt there is a need to reinstall this software is not there some link where can download the original software to do the installation using an SD, if you know let me know. Thank you.
  • 652 Answers
Sorry you will have to refer this to another expert.
  • 679 Answers
You may have unintentionlly "bricked it", it is not uncommon for these GPS programs to kill the unit when upgrading firmware or new maps, which are the same thing. Unfortunatlly there is an eprom in the GPS that would need to be reprogrammed. You can try downloading the map update to a computer and give it a go with the usb, even take out the sd card and use a card reader, "if your computer has one". But thats all you can do. I bricked one myself and I know better
Posted on May 18, 2010
  • 1 more comment
  • George Bill
    George Bill May 18, 2010
    I's sorry you aren't satisfid with the answer. But GPS devices use a chip, an Eprom chip, and once you mess with that as in a bad download, you are pretty much screwed. The only recourse you have is what I suggested or returning it to the manufacturer. It's not like a computer, it has a chip that is programmed by a special programmer, that costs thousands of dollars, I know this because I had a similar problem. I can usually undo anything I screw up, but not that particular issue. I see you are not happy with the answers you are getting. But the fact still remains, It isn't something you can fix by yourself. I am going out on a limb and telling you that you are wating your time trying to fix this yourself. Sometimes we must just face up to the truth, in this case the truth will set you free.
  • George Bill
    George Bill May 23, 2010
    Dude you are wasting your time with this. Unless you have an eprom programmer it is no good anymore
  • George Bill
    George Bill May 24, 2010
    You need a programmer to fix it
  • 721 Answers
Well it's not the country your in,lol. Motorola in it's classic crappy support (I also have a motorola so I can bash them,lol), offers no support for that model any longer. I found some links of interest though,check these out:www.taringa.taringa. net /posts/downloads/4147828/Actualizaciones-de-Motonav-tn20-y-tn30-gps-Motorola.html net / posts/downloads/4147828/Actualizaciones-de-Motonav-tn20-y-tn30-gps-Motorola.html , http://www.garbarino.com/promos.php?id=393
http://www.xataka.com/gps/motorola-motonav-tn20-y-tn30-navegadores-gps , try all those out in order. The first link is the guy's actual post,the others are the sources he refers to. It seems like motorola made a tn20 & 30 & both were dropped pretty much as soon as they sold all thier available stock,because they knew there was an issue trying to update or getting updates for that matter. The user manual is good for toilet use,since it explains nothing. Now the tricky part of this is,one the sd card needs to be from motorola,it's coded for that device only, & 2 you need a program compatible with your model. motorola doesn't offer any map updates, never did for the tn30 & only a few for the tn20. You didn't hear this from me, but there's alot of aftermarket programs that update the maps & prep any sd card to work. There's even some apps that are more modern that install on it too. Those links & some good Googling will find you everything you need to know. The main issue at hand is it lost power during the update & now it's corrupt. So somehow you need to refomat & prep the card with whatever motorola put on it in the first place,then try again to install the update,this time make sure it's plugged in to a constant power source until it's done. If you can't locate the "code" or whatever that motorola used, then using the methods above, search for iGO & the crack to unlock the tn30 so it will accept 3rd party software. The latter would be my choice. yelling at motorola goes nowhere. They could care less, just like HP & Compaq support. Hope this helps. I'm not worried about making money on this either. first we don't make ****, considering all of us experts have alot of schooling & experience. I like to do this when I'm not busy. Also, hardly anyone knows or even heard of your device,since the main market was outside the U.S.,ironically Brazil was the main buyer!! You'ld think they'ld definately support it there. Long & short of it is I spent better part of an hour looking all this up for you & I trully hope it helps. If there's anything else or something I missed just post back. I'll get an email & I'll be online for about an hour or so more. Thanks for using Fixya!!
Posted on May 16, 2010
You will need to download the Motorola TN30 software update, click on the link below to update:
http://direct.motorola.com/HelloMoto/NSS/Software%20update/TN20_TN30/start.asp
Posted on May 15, 2010
  • 3,083 Answers
Hi Mario, I tried to look up support for your device, and found a website that might be of help to you. Here it is: https://motorola-global-portal.custhelp.com/app/utils/chat
From this page, you can email or chat with someone from support, and hopefully find someone who knows how to fix your problem and help you.
I don't know if you've tried this site yet, but maybe it will help. This site also offers help for phones- go to the main support page and enter your information. Good luck- hope this helps.
Posted on May 13, 2010
    Top Expert:
  • 75,822 Answers
We can't provide u any support for this device.
  • yadayada
    yadayada May 15, 2010
    maybe i was not clear, we don't have the technical support needed to solve your problem, sorry.
    President:
  • 3,130 Answers
You should be able to coontact motorola for an instruction manual maybe even be able to send you to a downloadable user manual go to
mot_mailbox@custhelp.com
Posted on May 12, 2010
  • 15,935 Answers
This is a hardware failure - due to extreme temperature, drop or jarring while powered on, or incomplete/corrupted update.
The only repair is to return to the manufacturer for repair/reload of the O/S - however since you are out of the US, that will not be possible.
Thanks for using FixYa. Please accept this answer to remove it from the work queue.
Posted on May 11, 2010
  • 3,247 Answers
Not sure if you have access to the user manual for the TN30.
If not download the user manual from
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/MOTONAV%20TN30/Static%20Files/TN30_UG.pdf
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/MOTONAV%20TN30/Static%20Files/TN30_QSG.pdf
Not sure what files you are trying to copy and what you are using the USB for. The TN30 is a bluetooth enable GPS system and you have to use a bluetooth device like a mobile phone to communicate with it. The SD card is used for storing additional maps. The USB port on the device is used for charging but I don't think you can connect it to any computer.
It is best you download the manuals (setup guide and user manual) and check again.
If you need to upgrade the software on your Motonav TN30 then read this manual
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/MOTONAV%20TN30/US-EN/_Documents/Static%20Files/MOTONAV%20Web%20Download%20Install%20Instructions%20v8.pdf
Further details can be read at
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=3350622ec190e110VgnVCM1000008406b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
Please post a comment to make sure you are satisfied with my response. If not, please let me know where the problem is.
  • 1 more comment
  • Sam May 11, 2010
    Unfortunately I did not see the detail of the comments that you have responded to other fixy.com consultants. we don't get to see this until after we provide our suggestion. This is a limitation in the fixya.com system. I hope you are able to replace the firmware in the ROM. It is definitely something which only Motorola can fix.
    Sorry for wasting your time. Please do not rate my solution (2 fingers etc.) as I only see your original problem description and not the details of the comments you already have received for last 2 weeks or so. You can remove your ratings.
    cmmisure01.
  • Sam May 12, 2010
    This is cmmiuser01 - please remove the rating you have given to my solution as it is not consistent with the information I have provdided to you. I do not have access to the solution other experts have given to you and this problem is dragging unusually longer. There is a limitation on providing assistance if the problem does not appear to resolve.
    Thanks
  • Sam May 20, 2010
    I think you need to make sure you don't keep sending this problem back. A lot of the fixya.com consultants have tried to help you since 28th April but looks like you are not satisfied. It might be best to go to Motorola in USA and get it fixed as you decided in one of your postings.
    Most of the fixya.com consultants try to help on a voluntary basis without much compensation.
    President:
  • 803 Answers
Try finding the origanal firmware and reloading that to the device that should restore the device to factory default settings and software
Posted on May 10, 2010
  • 668 Answers
From our description it tends to be the problem of hardware , Contact motorola get it repaired from them . They will charge you around $50-100 for repairing it .
Hope this helps.
  • 2,427 Answers
You need to connect the device to your pc using theb serial port provided on the device. To update the firmware and revive the unit. Sadly this will involve contacting the manufacturer to send you the program needed and the cable. You may get the usb serial cable to buy locally and the company can email you the software and instructions for you. I saw you post a few days ago and didn't want to post hoping someone might have a better solution.
    Guru:
  • 312 Answers
The best way to get the information you need is to contact Motorola. There are so many different responses to your efforts I think best is to contact Motorola direct. Go to Google and write in Motorola support. Then follow through the result until you get the service department for GPS.
Hope this works for you. Sounds like it is scrambled for now. Darrell S
Posted on May 09, 2010
  • 1 more comment
  • Darrell Sorenson May 10, 2010
    If you will go to Google, type in " motorola tn30 GPS review" you can read a lot about your gps and surf further in to parts and service.
  • Darrell Sorenson May 12, 2010
    I sent you the address to use on google to get to the bottom of this. I am sorry I cannot do any more. Darrell S
  • Darrell Sorenson May 21, 2010
    I cannot give you any more advice than I have. I don't have the unit here and if you cannot get in contact through Google, I gave you the way to do it, I am of no help to you. I am sorry, Darrell S
    Guru:
  • 1,049 Answers
Ok, first thing you had asked for was the MOTONAV TN30 Specs, I've linked them for you. It runs on Windows CE, so the device software for your PC is just Microsoft Active Sync, nothing special there. But , obviously this means that the device won't work on Linux, Macintosh, or pre-XP versions of Windows. (I'll assume therefore that you are using XPSP2 or later and have installed the appropriate version of the Activesync software on your PC.)
The blue screen is a firmware issue if you're getting it on the MOTONAV and a sync error if you're get it on the computer. (But, I think one of the issues many of the technicians helping you have had is understanding where exactly your issue was)
If you are getting a blue screen on your computer when you try to sync or update the device, it is most likely a problem with the version of ActiveSync and/or Windows. You may need to backdate Activesync, run the software in compatability mode, or use another machine to get your updates.
If the issue is that the device blue screens then you will need to make sure that the memory is good and that the firmware is up to date. Follow these steps to download the firmware / system software of your Motorola Motonav TN20:
1. Head to Motorolas webpage to download the system software.
2. You will presented with this screen:
3. Find and enter your Motonav's serial number. Review the picture below to find the correct number on the label.
Good afternoon,
4. Pause for moment and consider the Purchase Date. If you enter a date here beyond the covered warranty period of your Motonav TN20
Since the default year of this screen is 2007, I recommend choosing a more recent year. Many people complain that they didn't notice this and get themselves locked out of what they should be entitled to.
5. Enter the Purchase Date, click Submit, and save the file somewhere on your computer.
The software download procedure is now complete. Follow these steps to install the new system software for your Motorola Motonav TN20.
_______________________________________________
Motorola Motonav TN20 Manual Download
Motonav TN20 Firmware Fix
Motonav TN20 Upgrade Manual
Posted on May 07, 2010
    Brigadier General:
  • 4,090 Answers
I dont know of any repair stations in Brasil But there is one is australia. Their address is GPS REPAIR PO BOX 321 Macclesfield South Australia 5153
Include return postage costs. They are the Mio Support for Oceania and SAm
  • dennis bullard May 15, 2010
    Australia 5153
    Include return postage costs. They are the Motorolla Support
    for Oceania and SAm
    I shopuld also say that your GPS is now discontinued and NO new maps are available for it. The cost involved to fix it may exceed the value of a newer 4.5" with new maps and warranty
  • 493 Answers
Maybe you tried everything to solve your problem. when I locked your question I am not able to see your previous comments. That's why excuse me for the same solutions if there is before.
You are saying that you formatted your SD but you need to be able to upgrade your GPS ROM.
Maybe the SD formatter software which you can download from this this link detect your GPS ROM flash drive. I am not sure but if you can manage that, then you may upgrade your device from here.
Hope this helps.
Good luck
Posted on May 06, 2010
  • Ibrahim OKTAY
    Ibrahim OKTAY May 19, 2010
    Please click this link. Then click Software update link in that web page as shown in the picture below and follow instructions.
    Hope this helps.
    Master:
  • 497 Answers
HERE IS A LINK TO TRY.. : http://www.motorola.com/consumers/v/index.jsp?vgnextoid=89b9f083ded00210VgnVCM1000008406b00aRCRD Go there and see if you can get and download any/all updates & software to solve your issue.. ok?
  • 3 more comments
  • Lynn Carmody May 06, 2010
    try this link... http://www.motorola.com/support/v/index....
    also, are you trying to link your phone with your computer? if yes, what computer & which operating system?
    here's one more link you can try: http://www.motorola.com/consumers/v/inde... GOOD LUCK TO YOU
    & LET ME KNOW..
  • Lynn Carmody May 13, 2010
    WOW!! I have been away from my computer for two days and when I logged on and read your comments, I REALLY UNDERSTAND WHAT YOUR ISSUES ARE BASED ON.... VIRUS INFECTION!!! To me , it now comes together and makes sense.. I should have thought of it before, but the BRAZIL based possibilities got me off track.. I am sorry for my ignorence requarding this. But now, re-analizing all commments posted up to date, I feel confidentent that your problems are associated with a virus or malware issue..
    With that said, here are some NEW SUGGESTIONS THAT I HAVE FOR YOU TO TRY...
    1) Please tell me the VIRUS PROTECTION SOFTWARE that you are currently using to Protect your computer.
    2) I recommend that you go to the following links I am providing, and Download/Install/Run these programs to search, find, and DESTROY any/all Viral Activities at hand.. Hopefully we will have caught them in time, and there has not been too much damage done. #1 http://download.cnet.com/Malwarebytes-An...
    & #2 http://www.norman.com/support/support_to...
    & #3 http://vil.nai.com/vil/stinger/
    PLEASE BE SURE TO DOWNLOAD EACH ABOVE FILE TO YOUR DESKTOP FIRST. Then from there, you will double click to open each program, one-by-one at the same time to run a FULL SCAN on each.
    3) After your have completed each Program Scan, Please Let Me Know the Outcome Results for Each OK? From There, I will Inform you on what to do next.. Please do all the suggestions that I have noted in order. Thank You and I will be awaiting your response.. Sincerely, LUCKY4LYNN2
  • Lynn Carmody May 15, 2010
    hello,
    I see that your issue still exists and that concerns me... Is there any way that you can return the item you have and get something that is more suitable and accessible for Services for your product in the area in which you live?
  • 821 Answers
Hello,.there could be a lot of causes to your issue let me list some.
1. Battery (just because you charged it does not mean its still good batteries have a shelf life of so many cycles)
2. corupted files on the unit (try the reset button should be a pinhole size stick a paper clip in there hold it until you see the splash screen)
3. Bad flsh memory
The issues with GPS devices are AGE,Betteries,corruption of files. Now to rule these out you need to think how long you had the unit.
If this is new well chances are you got a DOA dead on arrival or someone's returned unit. note: please try those steps and let me know if you got questions.
take care.
  • 1 more comment
  • Hammid Disu May 07, 2010
    hello,kindly tap your MENU key and you will have your motorola montonav tn30 in it's normal screen,or you kindly press the reset botton at the side to make you have your normal screen display.but before you click on the reset botton,you need to wait a while before you put it on.
    to turn on your tn30 montonav,kindly press and hold the power botton until the display becomes active to power it on.
    take care.
  • Hammid Disu May 19, 2010
    hello,please kindly visit the site below for a more comprehensive information about your motorola montonav tn30.
    http://www.productwiki.com/motorola-moto...
    wish you success,
    take care.
    hello,kindly follow the link below.
    take care.
    President:
  • 1,851 Answers
Here is on the house - please send the unit s/n - and the exact name and version of 'the program' you tried to install on your unit. Many times shutting off a unit while loading a program - any program - render's the unit inoperable.
Here is my suggesting friend. - Start over with a new unit and order it with 'the program' already installed.
  • Gary Rice
    Gary Rice May 19, 2010
    This is beginning to sound to me like a stolen unit the factory set to implode with the new system. I
  • Gary Rice
    Gary Rice Jun 01, 2010
    Good luck with your unit - IF I can be of any more help please let me know.
    Meanwhile p lease reconsider and give me a 4 hands helpful as I was as helpful as the next person as I can see?
    thanks again and
    GOOD LUCK
  • 11,896 Answers
You will need to download the latest software, drivers and a boot file after resetting the device. There should be a pin size reset button on the back
  • 13 more comments
  • Nate Stansfield
    Nate Stansfield May 01, 2010
    I am not aware of a software or drivers for windows 7. It will have to be updated but I would try and use a different computer with older os
  • Nate Stansfield
    Nate Stansfield May 02, 2010
    You can download a diagnostic utility that will scan and automatically repair any all problems with your pc. A registry cleaner may help like Glary Utilites.
  • Nate Stansfield
    I'm sorry we couldn't be of help.
    You can go to main fixya page and scroll to the very bottom to the contact tab and request to close your account if desired.
    I do believe motorola will tell you the same thing. To either reset the device, or to update the software. If neither one of those two work, the the device may be faulty.
  • Nate Stansfield
    Nate Stansfield May 03, 2010
    Not a problem. Thank You for trying Fixya. If you ever have anything else you need help with, feel free to come back.
  • Nate Stansfield
    Nate Stansfield May 04, 2010
    This manual may help you out a bit.
    http://docs.google.com/viewer?a=v&q=...
    Just highlight, copy and paste the entire link in your internet address bar. It is guide to all downloading, updating, and more.
    If reseting and updating still doesn't help, then you may have internal problems.
  • Nate Stansfield
    Nate Stansfield May 05, 2010
    You can try to use an sd card or usb flash drive to upload the software. Do make sure it is the exact version for your phone. They do make different versions. They do make a firmware flash device which is a bit expensive, but you can get it here:http://www.mightygps.com/compactflashgps...
  • Nate Stansfield
    Nate Stansfield May 07, 2010
    Just make sure there is no disk in the drive. You can also right-click on the drive, then go to properties, Make sure read only and everything else is UNchecked, then click apply. Then ok. Then you should be ok.
  • Nate Stansfield
    1) Click the WINDOWS START BUTTON
    2) Click over the Windows START BUTTON, there is the
    SEARCH engine.
    Click there and search for regedit
    3) Click regedit and the Registry Editor folder will
    open
    4) On the left menu, in order to make the folders drop
    down, click
    the following folders with an arrow as follows:
    HKEY_LOCAL_MACHINE,
    then,
    SYSTEM, then,
    Control, then,
    Class, then look for
    {4D36E965-E325-11CE-BFC1-08002BE10318}
    5) On the right side of this folder, you will see some
    files (probably
    with a small "ab" on a little paper which is an icon).
    Look for
    LowerFilter and right-click it and DELETE IT. Yes,
    delete the file!
    Don't worry if you think it could damage your computer
    system
    since, HOPEFULLY, you have already created a Restore
    Point
    for your system.
    6) After deleting the LowerFilter file from your system,
    RESTART your computer.
  • Nate Stansfield
    Nate Stansfield May 10, 2010
    I am thinking that this is an internal problem possibly to due hardware problems. May be a faulty I/C.
  • Nate Stansfield
    Sounds good. Let me know if you need anything else. Thank YOU for trying Fixya!
  • Nate Stansfield
    www.motorola.com/motoinfo/product/details.jsp?...270
    or
    www.store.motorola.com/mot/en/US/.../motorola?cmd...
  • Nate Stansfield
    Nate Stansfield May 11, 2010
    http://direct.motorola.com/hellomoto/sup...
  • Nate Stansfield
  • Nate Stansfield
    Nate Stansfield May 13, 2010
    Thank You!
  • Nate Stansfield
    Nate Stansfield May 21, 2010
    www.motorola.com/tn30/software
  • 369 Answers
Connect your mobile to computer and try to update the download the software from Motorola (tn 30) website.
  • 8,220 Answers
  • 2 more comments
  • Dan Webster
    Dan Webster May 01, 2010
    To make these GPS machines work right they need to know where in the world they are, just like you do. If you are in mountain country the machine may not be able to get a fix on your position. I believe this is the problem. Solution: Get to a place where the GPS can get a fix by at least 3 sats. Then follow the instruction mucho peeps have tried to give you on Fixya. Gracias amigo.
  • Dan Webster
    Dan Webster May 02, 2010
    MioPocket
    is an "unlock" (or alternate front end) for Windows CE-based devices,
    mainly GPS navigation devices (aka "PNAs"). It is an installable
    package of programs, scripts, registry files and skins to "unlock"
    GPS/PNA devices and allow them to be used for far more than just
    navigation (ex. for music, movies, appointments, multiple navigation
    apps, etc.). MioPocket is the most-packed and most-fully-featured
    unlock for PNAs available and is free and legal to use, as it consists
    100% of freely-distributable content. What MioPocket is not is
    a replacement for MioMap, Mobile Navigator or any other OEM navigation
    software. It is just a front end from which you may launch your device's
    navigation software or other navigation software that you've purchased.
    MioPocket
    comes with just about everything that you might want: three media
    players (video and audio, nearly all popular formats, including MP3,
    WMA, AAC, OGG, MP4, H.264, WMV, MOV, DivX, XviD and more), three e-book
    readers, multiple dictionaries (including English to 5 languages),
    dozens of games, two image viewers, two paint programs, MS Office
    document viewers, text editors, handwritten note-taking apps, four
    general GPS plotting/mapping apps, three different appointments/tasks
    apps, a contacts app, a calculator, a unit converter, registry editors,
    task manager/switchers, file managers, an alarm clock and more (all
    free/shareware). See the Readme
    file for a full list. Note: MioPocket does not come with MioMap, iGo,
    Garmin, TomTom or any other commercial navigation software. Icons and
    scripts are included for them, but not the programs, themselves (since
    they are not free).
    Technically,
    MioPocket should run on any Windows CE-based device. Due to the great
    many brands and types of devices out there, though, some will have
    better success than others when it comes to the ease of installation
    and the number of included features and programs that work. Most major
    Windows CE-based GPS brands, such as Mio (which MioPocket was
    originally designed for), Magellan, Navigon, Navman and Asus (and some
    other lesser brands) have installation instructions in MioPocket's Readme
    file. For obscure brands without included instructions, you may have to
    look around online (including the gpspassion.com forums) for unlock
    instructions and then adapt MioPocket accordingly... or be a pioneer
    and figure it out for yourself. Note that TomTom and Garmin devices are
    Linux-based and, hence, MioPocket (which is Windows CE-based) cannot
    run on them. GPS FORUM
  • Dan Webster
    Dan Webster May 03, 2010
    Best of luck Sir
  • Dan Webster
    Dan Webster May 20, 2010
    Ain't nobody gonna give you copywrited software. It is a violation of Fixya policy amigo. Suggest you give Motorola a go old chap.
    Motorola, Inc.
    Consumer Advocacy Office
    1307 East Algonquin Road
    Schaumburg, IL 60196
    www.motorola.com
    www.motorola.com/motonav
    1-877-MOTOBLU (Motorola Bluetooth support)
    1-800-331-6456 (United States)
    1-888-390-6456 (TTY/TDD United States for hearing impaired)
    1-800-461-4575 (Canada)
    The use of wireless devices and their accessories may be
    prohibited or restricted in certain areas. Always obey the laws and
    regulations on the use of these products.
    All features, functionality, and other product specifications, as well
    as the information contained in this user’s guide are based upon
    the latest available information and are believed to be accurate at
    the time of printing. Motorola reserves the right to change or
    modify any information or specifications without notice or
    obligation.
    MOTOROLA and the Stylized M Logo are registered in the US
    Patent & Trademark Office. The Bluetooth trademarks are owned
    by their proprietor and used by Motorola, Inc. under license.All
    other product or service names are the property of their respective
    owners.
    © 2008 Destinator is a registered trademark of Intrinsyc Software
    International, Inc. Unauthorized duplication is a violation of all
    applicable laws. Other names and brands mentioned herein may
    be the property of their respective owners. Patents pending.
    Map data: © 1993 – 2007 NAVTEQ. All rights reserved.
    © 2008 Motorola, Inc. All rights reserved.
    Genius:
  • 1,040 Answers
Dear Mario,
It seems that during installation process application has corrupted your software... So, reinstall the software... and everything will be fine....
Posted on Apr 29, 2010
2 Suggested Answers
  • 4090 Answers
SOURCE: Motonav TN30 frozen after install Miopocket 3.0
GPS REPAIR p.o.box 321 MACCLESFIELD 5153 AUSTRALIA
Motorola MIO DESTINATOR Support
OCEANIA REPAIR CENTRE
I want to unlock a motorola ce0168
Hi, You can unlock a Motorola CE0168 safer and easier using unlock code. You can get the accurate unlock code for a Motorola CE0168 from www.Mobile-Unlocker.Com at affordable cost with free unlocking instructions. good luck mate.
Jan 16, 2013 | Motorola RAZR Cell Phones
Motonav TN30 blue screen em "X" red
send the unit in for a warrantee repair
Techman
Apr 30, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Hi Mario, i beleive here is the link that you have been looking for to update your firmware/sofware for your Montonav TN30. Please click here.
Best of luck
Apr 28, 2010 | Motorola Mobility Motonav TN30 Car GPS...
I am trying to get europe/ireland england maps for my motorola TN 30 GPS not having much luck can you help
The original maps for this unit were supplied by Destinator, who have no ceased business. It is doubtful that nay other maps will work on this as they have not been made to operate with the TN30 engine.
Time to move on! 3.5 screens are obsolete also, most manufacturers are only interested in the 4.5 and 5" screen format now .
Contact MOTOROLA SUPPORT and ask them what they suggest
Please rate my help++++Thanks for using FIXYA
Dec 28, 2009 | Motorola Mobility Motonav TN30 Car GPS...
Gps use in Brazil
go to Motorola.com site and download the Brazilian maps. If they don't have them try NAVSAT.com and see if their maps are compatible. Good luck.
Sep 13, 2009 | Motorola Mobility MOTONAV TN20 GPS...
I m unable to connect my motorola v980 cell phone with pc
Hi, You will need the 'Motorola mobile phone tools' installed to use your cell on the PC. Here is a link to get it.
http://www.brothersoft.com/downloads/motorola-mobile-phone-tools.html
If you scroll down to..
"Motorola mobile phone tools in title"
you will see a list of downloads. Some of them are freeware and some you have to pay for, choose which ever one your comfortable downloading. This will allow you to synch everything, calender, photos, ect. Good luck, if this helps you plz take the time to rate this . Thank you kindly.
Jan 31, 2009 | Motorola Mobility V980 Cellular Phone
Usb charging
DATA pilot is a good program for motorola
Google it!
Jun 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Open Questions:
See all Motorola Mobility Motonav TN30 Car GPS Receiver Questions
Motorola Mobility Motonav TN30 Car GPS Receiver Logo
2,152 people viewed this question
Top Motorola Mobility GPS Experts
Are you a Motorola Mobility GPS Expert? Answer questions, earn points and help others
