Question about RCA P46924 46" Rear Projection Television
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
  • RCA Master
  • 8,457 Answers
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Apr 28, 2010
I recently had a convergence problem with my RCA P46924 Big Screen TV. No convergence setting in the menu. I simply took the lower back off and lightly feather dusted inside. No more convergence problems and the picture is better than ever!!!
Posted on Dec 12, 2011
I have a 2001 RCA Home Theater Projection TV Model p46924, Chassis # PTK195M34A. The screen all of a sudden started going dark and then just black. I have had it unplugged for about a month. Plugged it in...
Sounds like there is a hi voltage problem. Those 3 tubes are the most expensive parts to replace if you can find them. I. You can get an estimate for the repairs, but most likely they will approach the cost of a new flat screen smart TV.
Aug 06, 2017 | RCA P46924 46" Rear Projection Television
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Neon in color
sounds like you might need a good cleaning or your tv has contaminated coolant in the picture tubes. or you just might need to adjust the screen control for the picture tubes.
Feb 20, 2008 | RCA P46924 46" Rear Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
RCA P46924 46" Rear Projection Television Logo
262 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
