Question about Yamata PSP-990A Iron
I have a Prosteam garment steamer PSS-2001
I have a prosteam garment steamer PSS-2001 and I need a replacement cap for the water bottle? where can I find/buy in the US? internet?
thanks
Hi floyd, a friend of nime gave me a steamer and i dont know how to work it i dont know see where you put the water in at.i need to know step by step instrutions on how to work it.
what brand? what does it look like? should be a heavy screw-on cap on water tank. Fill with soft or distilled water, power on, and should be a red light that comes on when hot enough for steam
May 14, 2012 | Rowenta Commercial Garment Steamer - White
Ironed on synthetic fabric by mistake and fabric melted on the iron soleplate. How can we clean it off? Please Help! Thank you
You could turn the iron on again - set to cotton or highest setting and allow it to completely burn off. Do this outdoors or well ventilated area indoors (no smoke detectors on!)
Or, you could warm the iron and use a plastic putty knife to scrape as much material from the iron as possible. A metal knife will scratch and mar the surface. When cool, use a scotchbrite pad to buff away remaining deposits on the iron.
Mar 12, 2010 | Kenmore ProSteam 62888 Iron
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Sep 14, 2009 | Conair Compact Garment Steamer Iron
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
ProSteam Plus 34'' Steam Press with Steam Burst - Lost Manual
Prosteam Plus 34 steam press- the cloth has wornout. where can i buy. QVC has no contact details
Jan 26, 2009 | Irons
Yamata PSP-990A Iron Logo
499 people viewed this question
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
