VERTICAL PROBLEM NEEDS TO OPEN PLEASE ASSIST - Televison & Video
  • Novelo May 05, 2010
    yes sir i am ready to tackle this problem. The problem is that the picture looks wavey i have been told that it is the STK. Please asist me in solving this problem. Yours truly Novelo
  • Fal Mueller
    Fal Mueller May 11, 2010
    Diagnosing these faults require test equipment and a good knowledge of electronic repair techniques, and also a repair manual. Are you prepared to tackle this problem on your own
  • 438 Answers
Ok sir your ready so am i, my name is falco,
take the back off your tv, and get farmilier with its internal layout then the first thing i kneed to know is the nature of the wavies can you please discribe them in some detale
Posted on May 05, 2010
Shortly after the warranty was up the first vertical yellow line appeared and now, about 1 months later another vertical line appeared. He's not happy to hear it only gets worse and apple won't do anything...
Although its possible for graphics processor failures to cause vertical lines, they more often create horizontal ones. The first culprit to check for a vertical line problem is the LVDS cable, which it turns out is not that expensive a part (not counting all the work there is in getting to it). To verify this, I would gently flex the cable while the iMac is open and operating, and see if the lines get better or worse. It may also be that the cable itself is fine and just a few of the connector pins at either end are intermittent, in which case it just needs reseating.
Oct 18, 2010 | Apple iMac G5 Desktop
Sound but no picture
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
The disc drive will open when the Xbox is flat but will not when it is vertical. What do you think the problem is?
Flat vs Vertical causing tray to stick is just a mater
of offset loading in the sled and or gravity assist
during the eject sequence.
First I have repaired many 100's of 360's and I have noticed
when they are played vertical the Heat sink compound
will literally seep away from the G.P.U.- and C.P.U. so
I always recommend you play them Horizontal ( flat)
As for the stuck tray this is caused by a weak eject motor
and or grime build up in the gear train causing friction
witch prevent the motor from breaking open the magnetic
seal to the spindle. My simple remedy is to gap the hold
down magnetic in the hub so the motor can break the seal
with less force .
If you have any questions feel free to ask.
Rob
Sep 27, 2010 | Microsoft Xbox 360 Console
Is there a print screen key on my compaq laptop?
Yor notebook has Print Screen key. I would like to share that, to copy screen using you may need to follow the below steps:
1. Press Prt Sc key in combination with Fn key(Fn + Prt Sc).
2. Open the Paint program. On the edit tab, select paste.
For your convenience I am providing the hints to make the image smaller, press control w, and change the top two resize boxes to 80% in both the horizontal and the vertical box. Hit enter. This will resize the image to a size that is convenient to use for email attachments or as inserts in document projects.
I am sure that the above information helps. If you need any further assistance or clarifications, please feel free to reply to this mail. We would be delighted to assist you. I would like to share that, to copy screen using you may need to follow the below steps:
May 14, 2010 | HP Compaq Presario V2000 Notebook
My life frame picture is up side down how can i fix this? I have had a good look at the set up and cant fix the problem please assist Regards Manfred
Whatever program you are in - navigate to "webcam settings"
Open "Settings"
Click "Advanced" tab
Check the box "Vertical mirror"
Dec 12, 2009 | Ingram Computers & Internet
Hi, I have a 50" LG Plasma TV, LGE50PC1DRA and have red vertical lines across the whole screen. Can you assist? The TV will be 3 yrs old this month...Tks
Tv has a short on the vertical scan board, the board needs to be replaced. The board cost around $89 bucks its a pretty easy fix one you could do yourself....
Nov 03, 2009 | LG 50PX4DR 50 in. Plasma TV
SOLID VERTICAL LINE ON AUTO FEEDER COPIES
Hi Sally,
Open the flatbed lid and look on the left side, I believe there is the flatbed glass and another piece of glass to the left, the small strip of glass is the one used for the automatic document feeder. this piece af glass needs to be clean or you will get a line from top to bottom from any type of speck on the glass. hope this helps... if so please mark as FIXYA!!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Vertical lines on my laptop screen
Bad LCD, was it bumped or dropped?
Inexpensive replacement LCD at :
http://www.smartmicrousa.com/
I have used them for years, GREAT customer service.
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Vertical red
If your talking about the lines for the convergence, I would say it needs a professional alighnment or a componet, such as the convergence IC's are going bad on your TV set. there are no user replaceable parts on these tV sets, so unless you have any solid state repair experience, Play it safe and call in a pro to assist you in this repair. Good Luck PS Pleae do not forget to rate this thread.
Dec 07, 2006 | Mitsubishi TS-4545 45" Rear Projection...
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
