Question about HP OfficeJet 7310 All-In-One InkJet Printer
Paper is stuck in the rollers of my HP 7310 automatic document feeder--beyond the intial feed area and roller. How can I open up this area and clear out the mangled paper?
  • 4,041 Answers
Hello there Dont know if this may do the job ,but it worth a try.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Jun 30, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Auto Document Feeder sqeeks and groans
the problem is the cluthch that controls the feed roller, do not overdrive the the roller in the opposite direction it will damaged the mechanical clutch inside.
that is the one making the sound.
Jun 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper jams in document feeder
if u can do it,u need a special screw driver called T10,open the adf cover fist,there u can see four screws fitted at four cornersn one at the back,unscrew them,the adf unit will come out clean it properly,n also look for any peice of paper or anything like broken plastic etc,clean it n fix, n check
thnx N
Jan 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder doesn't feed well
Try Cleaning the rollers or separator pad
  1. Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. Close the cover of the automatic document feeder.
If this solve your issue pls let me know, if not ill try to look for another solution for you.
Jan 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Automatic document feeder
you have to replace it if cleaning doesn't help.
look for the seperation tire or pad if it picks up the paper from the top first then the sep is on the bottom and vice versa. Clean that on really good this is the one that seperates the paper and stops it from feeding more than one sheet.
Oct 21, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
