Question about Gateway 7330GZ Notebook
GATEWAY 7330GZ PC NOTEBOOK
I NEED ALL THE INFORMATION ,FUNCTIONS OF LIGHTS AND BUTTONS AND TROUBLE SHOOTING TIPS
DAVID
david_grunden2000@yahoo.com
THANK YOU SO VERY MUCH
  • Anonymous Apr 21, 2008
    BIOS Issue. When The PC turns on, I get a Message, that the CMOS Setting is wrong.& CMOS time not set. Press F1 to run Set-Up. I've set up the date & time. And it reboots fine. But the next time I start the PC I get the same BIOS Screen, so I once again Set the Date/Time & in Advanced Settings I pressed Gateway Default Settings , Save Settings, & OK, then PC started Up Fine, But I keep getting the same Error Message the next time I start my Gateway 7330 GZ.Can someone help me, I would appreciate it. Thanks
    Genius:
  • 1,027 Answers
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Posted on Mar 24, 2008
I bought a gateway online on ebay. Cant get keyboard light to light up. I have tried to use function keys. Dont work. Do i need to replace keyboard. Are the lights even located in...
no if you bought it on ebay more likely than not the correct keyboard drivers are not installed are the previous user wipped it simply search for the correct driver download it open control panel> device manager> find keyboard driver and update it to the correct one
Feb 27, 2011 | Gateway 7330GZ Notebook
How do I enable the wireless switch on a Gateway mx8711
HI there,
Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide.
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page. Another source of reference for networking your computer is the Gateway Notebook Networking Guide. Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Hope this helps you out.
TheSelkie
Jul 21, 2010 | Gateway MX8711 Notebook
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
7330GZ won't turn on
I had the same thing happen to my computer 7330 gz and all the trouble was caused by a faulty ac adaptor. Battery wasn't holding a charge either because it's 3 years old and worthless. I got a replacement adapter at best buy for 100 buck and it's universal. Fixed it up just fine and now I'm sharing my solution with you!
Nov 19, 2008 | Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis assembly..plus you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
7330GZ Gateway laptop keyboard doesn't work
There is one thing you can try. Uninstall the drivers for the keyboard from the device manager, then reboot. The machine will find the keyboard and reinstall the drivers automatically. If this doesn't work, then I'm afraid the Shift key function has failed and the keyboard will need replaced in order to fix it.
Aug 25, 2008 | Gateway 7330GZ Notebook
7330GZ ethernet controller
http://support.gateway.com/support/drivers/getFile.asp?id=19871&dscr=Gateway%20Intel(r)%20Chipset%20Driver%20Revision:%205.1.1.1002&uid=203866825
Jul 31, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ laptop. Good battery, good Ac Cable will not turn on?
The system board on the laptop needs replacement.
Hope this helps :)
Nov 25, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
549 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
