Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
I bought a Sony 50" LCD Projector television
I bought a Sony 50" crt tv 3years ago. Picture quality is bad. It appears the RED of RGB is faulty. My local service technician is unable to solve problem. Please, advise.
E.M.Sarkodie
  • 336 Answers
Sony kdl55nx720 picture settings
Your are the one that knowing the best settings for your TV..To adjust the picture make it sure that all colors are appear like RGB red,green,blue on your screen to easily set the best picture,,..
Dec 28, 2011 | Sony Televison & Video
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
Kv32526 32" sony no picture everything else is ok can hear voices can change channels 1997
you should check the RGB, check the heater voltage from Fly back to the heater (CRT Tube), make sure there are about 5 VAC Voltage, if no damage is usually there at 1 ohm resistors, other than that the damage can be caused by any part of an abnormal color, RGB voltage not equal or one is weak or not functioning. in other words, the color Green or Red and Blue did not appear. consequently it will not appear on the screen image. the solution is to replace the CRT tube or CRT tube Recharge using special equipment recharging....
Sep 30, 2010 | Sony KV-27FS16 27" TV
I bought a SONY GRAND WEGA LCD Projection HD-TV about 2 years ago i rarely use it about 6 to 7 times,i turned it on lately and the screen shows no picture ,power light blinks yellow for a few seconds then...
Its possible that one of your fans has failed, and or it could be the lamp itself. Sony television will not power on if a fan is faulty. Open the back of unit and look at all fans to make sure they are running, if so then replace your lamp.
Oct 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Popping; sparking of Red Projector to metal frame
Sounds like the red CRT has an internal short. Sometimes happens that the picture tubes develop an internal short and cause arcing. I world CAREFULLY disconnect all of the wires to the CRT and see if the arcing goes away. VERY IMPORTANT!!! there is a high voltage wire attached to each pictur tube, usually a red wire that goes to the side of the tube. You can get a shock even if the TV is unplugged, as the tube will hold a charge for years after the power is disconnected. If you don't feel comfortable doing this, DON"T since the shock is powerful enough to stop your heart.
Oct 18, 2008 | Sony KP-61XBR48 61" Rear Projection...
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Picture Brightness Flickers
could be one or more of three things.
1.could be the crt itself.(sony had a bad bunch of crts for this model)
2.could be the vertical ic on crt board.
3.could be the focus block
in my experience solutions 2 and 3 are more common....
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Breakout cable usage
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Oct 15, 2007 | Panasonic TH-42PWD5UY 42 in. Television
Kp-46wt510 rear projector
Have you tried adjusting the red screen control located inside the front of the set? Usually behind the speaker grill. It is part of whatis called the control focus/screen block. There are 6 controls on this assembly. Be extremely careful high voltage is present. If you turn the red screen control and no red is seen onthe red gun , there are two possibilities. A) bad picture tube B)open filament connection on crt board. Scrivitron
Jun 04, 2007 | Sony KV-27V22 TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
