Question about Kenmore Oasis HE 27082 Top Load Washer
My washer shows a HC in the panel. what does that
My washer shows a HC in the panel. what does that mean?
  • 299 Answers
HC means that the Hot and Cold water lines are reversed. Make sure that the supply hoses are connected correctly. If they are, then there is a problem with the sensor or control board.
Posted on Apr 28, 2010
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
SYMBOLS ON THE PANEL
That means that you have the hot and cold hoses hooked up to the wrong inputs. Switch them.
Feb 02, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer shows a code HC...what does this mean?
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a kenmore elite oasishe washer and it keeps setting off messages that I am not sure the meaning of. It finished washing the other day and it had hc on the machine what does this mean?
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min.
Restore power to the washer and try running a short cycle.
This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
What does HC code on washer mean. Do not want to know how to fix it at this moment, just what does it mean
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$#@!
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I need to know what the HC code means?
Aug 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
When the washer is finished washing. what does hc mean
Jul 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
174 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
