Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon Pixma MP 780 printer will not print black text or anything else requiring black. I have replaced the Black 3e cartridge. What do I try next?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
    Problem Solver:
  • 18 Answers
CANON MP780 BLACK DOES NOT PRINT
This is what works for me. Try at your own risk. You may need to cleane both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
#6
Posted on Jan 04, 2011
IP4000 - How can I force the printer to use the large black (6) ink cartridge?
Do you mean the large black ink as in the 3e vs. the 6? If so, the large black, 3e, is a pigment based ink and the printer should only use it when print text and black and white things. The 6 black is a dye based ink and the printer should only use it when printing photos.
Jan 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My black ink has all but disappeared. I have
Order and replace the printhead, QY6-0049-000 around $50.00. Black is the first to wear out on Canon printheads.
Jan 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Black will not print
This may seem obvious but have you tried cleaning and refreshing the print heads? I've had a similar problem with only certain colors and the cleaning seemed to help.
Nov 06, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,004 people viewed this question
old marine
old marine
