Question about Troy-Bilt Pony Garden Tiller
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
I have put on a new air filter, spark plug, new gas line and gas line filter. I have also removed the old gas from winter and added new gas.
I have a 8 hp troy bilt i bought used it had been sitting about 3 yrs now it wont start. its not getting gas to the plug it is getting gas to the carb any suggestions.
Posted on May 31, 2010
  • 718 Answers
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Posted on Apr 29, 2010
Troy bilt troubleshooting
-Try replace spark plug first. If still do that then the ignition coil is bad when it's hot.
Good luck
mai
Aug 28, 2014 | Garden
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
My 5 horsepower pony tiller just shuts off with no warning after about 20-30 minutes of tilling and will not restart again until it cools down to the touch I have changed the spark plug, drained and...
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Mar 23, 2011 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Have a troy bilt trimmer that starts fine but will die when you try to use it. I have put new gas and spark plug in it and cleaned the air filter. It acts like it's vapor lock. I use regular unleaded gas,...
If your gas is older than 30 days, go out and mix up some fresh gas mixture before going any further. Other wise it sounds like the carburetor needs rebuilding or adjusting.
Note: There may be alcohol in your gas and you may not know it.
Sep 24, 2009 | Garden
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
LOOKING FOR A MANUAL FOR A TROY BUILT TILLER MODLE 1003W
Tiller runes for and about and hr then it stops but it will start up when you pull the rope and and it
will run. You go to till and it will stop it has a new air filter and spark plug in it.
What is next.
Dave.
4 / 11 / 09
9 ; 51 / A / M
Apr 09, 2009 | Troy-Bilt Garden
Troy-Bilt Pony Garden Tiller Logo
493 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
