Question about Kitchen Ranges
Maytag neptune washer mah8700aww getting error ( te )
  • J-run Apr 28, 2010
    THE ANSWER IS CORRECT, THANKS FOR YOUR HELP AND LOOKING UP THE INFO. I VERIFIED WITH WHIRLPOOL TECH LINE I'M AN AUTHIORIZED REPAIR MAN FOR WHIRLPOOL, AND WANTED TO SEE HOW ACURRATE OF AN ANSWER I COULD GET FROM THIS SITE. THANKS AGAIN FOR YOUR HELP AND TIME.
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
The tE error means that there is "Abnormal high/low temp or ohm resistance seen" Diagnostic Code 29. This means "Sump thermostat Failure (optional)" as the description, and " Loose or pinched wires or bad sump thermistor" Please try to kick it into Service Mode again. Then try to the "Quick Service Cycle". Next try to run a standard full wash cycle with no load to check it out and the unit should run fine. I believe the spilled bleach got onto something that is not insulated anywhere near as well as it should be in an appliance that uses water to operate. The liquid could have caused a minor short to the frame that allowed the resistance in the thermistor wiring .
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 28, 2010
I have a Maytag Neptune MAH8700AWW with error code tE, lower case t and upper case E. What causes it. I finally got it in diagnostic mode and it says U133 but wont go any further.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
Hope this helps.
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
Jan 19, 2010 | Maytag Neptune Washer
Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Jun 14, 2008 | Maytag MAH8700A Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
