Question about Whirlpool MH6150XL Microwave Oven
My Whirlpool microwave won't turn on. It says door on the display and it is closed tight.How can i fix it? Thanks
techman
  • 3130 Answers
SOURCE: Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
Posted on Jul 30, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Loose microwave door
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position. I would even bet it's in the top switch or holder! *grin* This is especially common on Sharp over-the-range models such as R1460, R1461, R1480, R1481, etc. Feel free to e-mail me with your model number at _ if you'd like to discuss this further. Always happy to help.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9047 Answers
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Posted on Nov 02, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool GT4185SK Keypad does not work - oven starts as soon as door is closed
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
Another thing that can cause this is steam or grease / smoke getting in the controls. The best way to prevent this is to be sure your hood exhaust fan is on whenever you cook on the stove top.
If it does not dry out over time, it may need to be manually dried or blown out.
I've followed up to your by e-mail address to be sure I help you fully.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
Door error message on microwave whirlpool Gold rmc275pd
This indicates the door is not latching. The simplest fix is if it really isn't closed, and simply pressing on the door does the trick. Not so lucky? Latch mechanism itself may be dirty and not latching. Try cleaning it with standard spray kitchen cleaners and a good scrub, followed by a toweldry. Still no good? There's often an electronic interlock-- a place outside the latch, perhaps along the face of door, which must contact the body of the microwave oven. Again, try cleaning all possible contact areas. No? OK: microwaves are designed not to run without a tight seal to prevent emissions. perhaps the seal itself is damaged. Finally, and most unhappily, and expensively, the electronics module in the combo unit is shot. If the appliance is under warranty you're in like flynn; if it's relatively new but not under warranty, call the Whirlpool service 800 number and very politely but firmly remind them that this is really quite a new unit and certainly their products aren't meant to fail so soon... and surely they have a service bulletin because this can't have just happened to you... This will usually result in (oh happy day!) a free service call or (more common) a deal to sell the part at half price. Better than nothing!
Jul 03, 2012 | Whirlpool RMC275PD Microwave Oven
The microwave display shows "Door" and it won't
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Aug 03, 2011 | Whirlpool GT1195SH Microwave Oven
My microwave not starting
My microwave on top of stove oven,whirlpool gold. When i closed the door but it keep said"door"and won't start.
Jul 21, 2011 | LG MS-0744Y Microwave Oven
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
I have a Whirlpool GMC305PDS07 Oven Microwave combo. The microwave display shows "Door" and it won't start. The door looks fine and closes properly. Is there anything I can check or do before...
Sorry to read about your problem, I hope this helps you out.
sound like you have a defective door closed switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Whirlpool GH7145XF Microwave Oven
Is there a reset button on the whirlpool microwave JT 358??
hi my name is mark, if the display shows close door then the door switch has failed or is stuck. oven will have to be disassembled to find out. if you do, unplug unit first, before removing cover. thanks for your question.
Mar 12, 2009 | Microwave Ovens
Whirlpool MH6150XL Microwave Oven Logo
701 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
