Question about Dell OptiPlex SX280 PC Desktop
Power light flashs off and on and pc clicks
The Power lights flashes green/amber and the PC clicks repeatedly as though it is about to turn on but doesnt. I've tried replacing several caps to no avail. Can I get a schematic somewhere ?
    Sergeant:
    Novelist:
  • 172 Answers
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Posted on Apr 28, 2010
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
My optiplex 330 is not powering up.the power botton flashes orangy bright when the pc is turned on.what the problem there please
The common issue related with a Flashing Amber Power Light is a BAD POWER SUPPLY. If the Amber Light is SOLID then it may be your MOTHERBOARD.
But if it is flashing repeatedly then it is your power supply, you will need to purchase a new one. Good Luck.
Oct 08, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Dell OptiPlex SX280 PC Desktop Logo
851 people viewed this question
Alun Cox
