Question about Toshiba CZ36V61 TV
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Posted on Apr 29, 2010
Testimonial: "you are a genius!!!! it worked!"
  • Toshiba Master
  • 8,457 Answers
Ur remote is shorted.The remote CPU chip is shorted,many tvs models have this kind of remotes problems.Some functions are still goods orther are not.U can't repair this except,changes batteries,don't work must replaced the remotes.Try website 1-800 remotes Factory original.Buy an exact remote,or very close to the original.
Posted on Apr 28, 2010
Remote sensor on tv not responding I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley...
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Jul 17, 2012 | Sylvania LC420SS8 LCD TV
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
Toshiba remote stopped working
remotes run on infra red technology. that part of the remote could be damaged. if this is the case its just cheaper to get another remote. just remember if you get a universal one .. you keep the code book.
Apr 28, 2009 | Televison & Video
Toshiba TV Remote Control not working
Hi
can you give to me your exact problem?
Thanks!
Sep 22, 2008 | Toshiba 30HF85 30" TV
Wc-fm2 remote not working
Mine does not work any more. I tried a Toshiba replacement but that does not work either. Sometimes it would power up but the menu and channel change did not work nor the volume.How can I determine if it is the TV and not the remote.
Jul 13, 2008 | Toshiba WC-FM2 Remote Control
Remote has stopped working for Philips LX3000 D
The remote control might be damaged. If it is possible to arrange a new remote for testing, do it. volume control of LX3000D works from the front PCB. check the front PCB is perfectly ok or not. Regarding the DVD player, what it says when you try to load a disk?
Apr 10, 2008 | Philips LX3000D System
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Toshiba CZ36V61 TV Logo
177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
