Question about Hayward Navigator Pool Cleaner
Just bought a new sweep because old one didn't move....this one still very slow, any ideas?
  • 990 Answers
This could be an air leak, a partial clog in the line, a clogged impeller, a clogged filter or an underground leak. Without more info I can't say more than that.
Posted on Apr 28, 2010
I"ve bought 2 new actuators and plug them in, when I turned the heat or air on manually the switch on the actuator didn"t move. Any ideas?
What are they for? We need the year make and model of the vehicle and where you installed those
Jan 25, 2016 | Cars & Trucks
Radio not working
Did you check to see if you wired it the same way you removed it? Make sure you are wiring it the exact same way as it was initially.
Jun 09, 2017 | 2000 Ford Contour
88 2.9 ranger sputters at 2500 to 3000 rpms when i drive it. it runs fine until i try to get on it or get into higher gear and rpms ut spits and sputters
If all plugs ,wires etc have been done, next i would confirm proper fuel pressure, then I would check throttle position sensor. An old analog ( with sweeping arm) multimeter on ohms, remove connector at TPS and connect to 2 of the pins on TPS .(throttle position sensor) Engine off, rotate throttle, or have someone push it from inside, slowly, gradually and needle of multimeter should sweep across as well, if not try different combination of 2 pins. When you find right combination that makes needle move when throttle pushed, observe the needle as someone pushes throttle slowly and steady from slow to wide open. If the needle jumps, or falls off and comes back up as throttle steadily pushed, then replace the TPS. If the needle slow and steady moves up /across and no stumbling, the TPS is probably ok. Make sure you test it a few times at least.
Feb 17, 2012 | 1988 Ford Ranger
Synching Itunes
To Transferring Playlists
If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop.
Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing.
Source:http://support.apple.com/kb/HT4527
Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
Dec 02, 2011 | Apple iTunes
Hi, My windshield wipers are not working,just one slow sweep. It isn't the switch or the motor but rather something electrical. Any ideas?
Not sure how old this post is...This happend to me yesterday. My control panel which hold fuses needed to be replaced. I only have 43,000 mi on my 08 Compass and it was not covered in my Certified Jeep program. It was about $500.
Nov 28, 2009 | 2008 Jeep Compass
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Hi there
Hello
that depends
is the old disk a IDE disk?
do the new computer have a IDE port on the motherboard?
if so you can put it in your new computer. but you cant move your OS and use the same disk. you can use is as storage.
I quess that your new computer has sata right? and I think its a bad idea to move your maxtor disk to the new computer because it can slow your PC down.
Good luck
Sep 02, 2008 | Maxtor Hard Drive
Hayward Navigator Pool Cleaner Logo
197 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
