Question about Roper RAB5232E
Where are the belts located in a roper washing machine?
  • 5,911 Answers
If the model number you posted this question under is correct, this model Roper does not have a drive belt. The washer uses a motor coupling in place of a drive belt and is known as a direct-drive system. The following link shows the drive system of your washer:
http://pcappliancerepair.com/model-display.php
The motor coupling is listed as item 13.
Symptoms of a broken motor coupling include failure to agitate or spin accompanied by the sound of the motor running with no tub action. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, or if the symptoms I describe do not match the problem you are having, please post back with your complete MODEL NUMBER (if different from the one listed) and let me know. I hope this helps you.
Posted on Apr 29, 2010
I have a NEW Roper Washer. It agitates somewhat slowly. My old washer agitated FAST. Is this normal for a Roper?
I would have a look at the cam dogs located in the agitator and the motor coupler or belt if not direct drive. check for loose clutch or slipping tranny. also check for worn agitator spline
agitator coupler bell housing removewasher101-r0vmhnqx3ofapyttmvvmotan-4-9.jpg
Apr 15, 2017 | Roper Washing Machines
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
How to take back off of a roper washing machine
Your washer does not have a belt! It operates on a "direct drive" concept. You could have an issue with one of the following:
* spin/lid switch
* drive coupling assembly
* timer
* motor
Contact an appliance service company.
Feb 24, 2010 | Roper Washing Machines
Roper RAX 5133AWP WASHER WONT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 12, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer washes but doesn't drain during spin cycle.
2. Water Pump
Jul 10, 2009 | Roper Washing Machines
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
Changing a belt on roper top load washer
There is no belt on a roper. It called a drive coupler. its direct drive. Go to sears online and go to the parts section and put in your model number. Look at the diagrams and it will show you where it is located (easier to show you than to tell you.)
Nov 16, 2008 | Washing Machines
Belt-how to
probable pull machine out from wall check underneath for belt
yuo may have to remove motor to fit correct belt to this machine
Mar 15, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
289 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
