Question about Cameras
The battery cover is broken, spring gone so wont shut properly and no contact with battery. Canon pc1059
  • cbarfoote Mar 25, 2008
    Hello kman,
    Thank you very much for your reply. I have tried several times to order the battery cover thru the website you sent me but it comes up with an invalidation code saying there is a problem with the address and/or zip code. Can't figure this out.
    Regards Cheryl
  • Cameras Master
  • 19,396 Answers
Yo need to change the battery cover , if yo give me your location, I can find a replacement in your area.
Posted on Mar 24, 2008
  • 99 Answers
You can buy a replacement battery cover here $14.95:
http://www.darntoothysam.com/servlet/the-197/Canon-Powershot-A80-Repair/Detail
If you can do it yourself could be worth it. If you need to send out for repair would probably be cheaper to buy a new one for about $100 or so.
Hope this helps!
  • Kyle
    Kyle Mar 25, 2008
    Make sure that if using a credit card that you enter the address exactly as it is on your credit card statement. That might be why not working.
    They also take Paypal.
    Let me know how you make out.
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
Despite changing batteries constantly, camera wont work properly. With fresh, new AA batteries, camera will take 1-2 pictures and then low battery light comes on , then camera shuts off
hi, this can be happening due to some bad battery contacts in the camera. take some cotton buds and clean the lower and upper contacts of the camera. this will help you. else revert back to us. thank you sweet rascal
Oct 18, 2009 | Canon PowerShot A75 Digital Camera
My battery cover is broken and the camera will not power on. Will the camera work without a battery cover?
Very often they won't as there are spring contacts onto the battery inside. The battery needs pressure to keep it in contact.
Aug 16, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
It wont turn on
On TI-83 Plus and TI-83 calculators that have the newer flat screen (as opposed to the first generation TI-83 with the tilted screen):
1. Open the battery compartment cover
2. Install known working batteries
3. Using a voltmeter, insert probe ends into the holes right beneath the 2 center batteries and touch the circuit board on either side. One is a (+) side and the other is a (-) side, so both must be touched. Be careful to ONLY touch the copper square of the circuit board. If your voltage reads 0 or very low (1-2 volts) proceed to step 4. If your voltage reads about 6 volts, your problem lies elsewhere.
4. Using a voltmeter, insert probe ends on the bottom of the 2 outside batteries where the springs are visible. If voltage reads about 6 volts, proceed to step 5. If voltage reads 0, your problem is that the springs are not making good contact with the batteries due to corrosion or weak springs. You will need to clean them or get donor parts. Find a calculator with a broken screen that comes on and swap the back covers. Details on how to remove the back cover further on.
5. Using a T6 torx electronics screwdriver remove all 6 screws on the back and using a small phillips, remove the backup battery cover.
6. WARNING! Disassembling your calculator can cause unrepairable damage. Only proceed if you have no other options! Using a small flat electronics screwdriver, pry into the case on the side about 4 ridges up where there is a small hole. Pop both sides open and break case away from the bottom to the top- NEVER FROM SIDE TO SIDE. (Going from side to side can damage the I/O port.)
7. Look at the copper squares at the bottom of the board. You can see where 2 springs make contact from the back cover. Often this is dirty, corroded, or the springs are weak and not making contact. Clean this area with alcohol and gently scrape away any oxidation.
8. Put calculator back together and test. When a calculator will not turn on, this is likely the culprit.
I have fixed several calculators with this method.
Dec 16, 2007 | Texas Instruments TI-83 Plus Calculator
No Battery Life
On mine, the battery terminal on the inside of the battery case is broken, by opening and shutting the cover a few times until it contacts properly it is normally OK. Anyone know where I can buy a new contact plate in theUK?
Nov 10, 2007 | Casio Exilim EX-Z120 Digital Camera
Battery cover replacement
First, replacement battery covers may be obtained from dealers in the USA - I got mine from San Diego Camera Solution who list the item on eBay. Haven't found a UK outlet, but I guess Leung's at Goodmayes would offer a repair service if you don't fancy DIY.
(Disclaimer that I have no connection with either company).
Not sure what Canon recommend, but the easiet way (worked for me) does not involve stripping the camera down. If you dissemble the old and new battery covers via the three little cross-point screws (see warning), then it is possible to replace the new cover around the original hinge assembly.
The advantage of this method - aside from not opening the camera - is that there are "spares" the bits that will get dropped (spring and screws) so that there is less time wasted trying to find them while effecting the repair!
The trickiest part is the sprung loaded latch, which must be installed with the spring partly compressed. Beware when first taking the covers apart and especially when refitting, because the spring will do its utmost to escape.
Sep 22, 2007 | Canon PowerShot A640 Digital Camera
Camera was dropped and is not on
Take batteries out and have them checked, and make sure they are fully charged. Take a pencil eraser and clean/polish the contacts at base of the battery compartment Take a look at the battery-comp cover place and make sure the contact plate is firm replace batteries switch on OK No? Open the battery compartment, place a piece of foil across the batteries and shut it - turn on -OK No? Press the cover in OK No? Them it has broken beyond your reach and needs repair or replacement
May 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
