Question about Xante PLATEMAKER 4 Laser Printer
We have an xante platemaker 4, if we create a box using Indesign 5.5w x 8.5h and print to the platemaker, the box is 5.437 x 8.5. It seems to be shrinking the box by 1/16". When we print to a standard printer, the box is the actual size. We have checked to make sure all the settings are at 100% but can't find the problem. Please help as we are doing prepress layouts and it has to be the exact size.
3 Suggested Answers
webster1280
  • 5 Answers
SOURCE: Image enlarging when plating!
Try outputting a pdf of your document. Set up your page from the printer window and print from Acrobat Reader. Also check your network connection if you are on ethernet. AppleTalk work much better in mac osx tiger vintage mini mac. I have not tested all the printer drivers yet on the new mini mac Lion. But there is less of a compatibility issue if you convert your doc to a pdf file. Hope this helps. :-}
Posted on Jan 29, 2012
richardthelh
  • 3 Answers
SOURCE: Unable to get Xante printer to work
The other option is to use the web page of the xante to print, I do this using mac os 10.4, since it stopped working in the printer menu. Xante support is poor at the very least and sucks at its best.
Posted on May 10, 2012
Cover open?
Dear its your Platemaker 4 front cover open massage i think please check its right behind the front panel,its not easy to check it first removed the panel cover side cover after that formatter board,fuser assembly you can observe that its communicate with gears,found in main engine there is small lever who controlled front cover,hope you understand.
thanks.
May 13, 2014 | Xante PLATEMAKER 4 Laser Printer
Screen Setup
Do you mean for screen printing? How many colors? You need to assign specific LPI's, angles and dot type depending what you are trying to print. Your art also might need to be set up better. Can you send link to image and print?
Apr 01, 2014 | Xante PLATEMAKER 4 Laser Printer
Manual tray feed problem on Xante Platemaker 3 laser printer
You may have to change your settings in the program you're printing from to say "tabloid" instead of the plate size. You basically set everything to make the printer think it's printing 11x17 paper instead of a plate. The only thing I leave the same as a plate is the setting in Quark that says, "Media Type". I leave it on Polyester Plate.
Dec 23, 2008 | Office Equipment & Supplies
hi pip,
check your mac properties, if it is a PC powerchip, you may have to enable "Rosetta" in the indesign applications properties folder.
this may resolve the file print size conversion process.
Rosetta is inbuilt in mac with this type of powerchip, and when activated, works in the background..
http://www.apple.com/rosetta/ this link will give u an insight
not sure this is your answer....cheers rooboy
Dec 08, 2008 | Xante PLATEMAKER 4 Laser Printer
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
May 17, 2008 | Xante PLATEMAKER 4 Laser Printer
Sending a plate from word
Not familiar with the printer or if you are using
Windows or Mac but there should be a page setup
tab to set oriientation for Portrait or Landscape
Margins etc
Nov 16, 2007 | Xante PLATEMAKER 4 Laser Printer
Screens Picking off on press
the problem is due to the fuser not to anything else seems that the fuser do not heat up the toner enough, what i did is to run the plate twice , as blank of course . it did the trick for my press.
Apr 23, 2007 | Xante PLATEMAKER 4 Laser Printer
Open Questions:
See all Xante PLATEMAKER 4 Laser Printer Questions
73 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
